Bandit has a complete exhaust system now. I used the factory hangers and tucked the pipe up inside the frame rail so it doesn't hang down at all.
My back was killing me and I had to work too hard to get the exhaust done, so while I have the helper clean the shop up tomorrow, I'll be making a drive shaft.
Fuel lines
Accessory brackets
Front and rear drive shafts
Radiator and support
Batteries
Trans controller and harness
I think that's it. ....and then weld up all the rust and build the front spring packs.
At the very least, I should hear it run this week.
