glow plug system malfunction
Old Dec 7, 2013 | 10:01 PM
drs1963's Avatar
drs1963
2004 6.0 stock. 278,000 miles always started in cold weather until today.No engine codes, ficm voltage is good. Pulled all 8 glow plugs and ohms read between 1.4-1.5. I really thought this was going to be my problem, so time to look elsewhere. Just happened to check the harnesses on the engine side and reading 5.5 volts on all 8 pins with the key off. Is this normal??? Think it should read 0 until the glow plug circuit is made? Is it time for a gpcm? Any thoughts
Old Dec 7, 2013 | 10:35 PM
78fordman's Avatar
78fordman
What is your cranking rpm and voltage?
Old Dec 7, 2013 | 11:08 PM
drs1963's Avatar
drs1963
everything is normal and it starts and runs fine if I put it in the heated garage. I do have a scanguage and moniter voltages and such, just wasnt sure about the no start today and finding voltage at the glow plugs with the key off
Old Dec 8, 2013 | 05:50 AM
78fordman's Avatar
78fordman
May just be scr leakage. Again what is your voltage and rpm during cranking.
Old Dec 8, 2013 | 11:12 AM
drs1963's Avatar
drs1963
rpm is 0 cause the glow plugs are removed so not cranking it, battery voltage is 12.6volts, ficm 48volts. nothing is turned on and the key is out of the ignition. Still getting 5.5 volts on both banks of glow plug harness. is this normal???? I wouldnt think so as there would be a drain on the batteries at all times
dioxippus
Apr 14, 2016 12:38 AM
PJ-Hunter
37
Jan 7, 2016 07:25 AM
ranagent
15
Sep 8, 2015 07:37 AM
natedowney
Nov 6, 2014 07:32 AM
1L243
Dec 31, 2011 09:04 PM
