Glow Plug harness removal trick
Old Dec 7, 2013 | 06:18 PM
dr67's Avatar
dr67
I thought I would share a little trick I learned for removing the harness without breaking it. I have removed at least 10 sets without breaking a single one. The tools
I use a Snap on hose pick, and the glow plug harness removal tool. Here is the catch. The valve cover must be removed. It seems like most of the time it has to come off anyhow.
anyhow reach in and pull on the harness from inside with the pick while gently pulling on the harness removal tool. You want to let the pick do most of the work.
I moved the oil rail aside just for the photo op.
I realize this is a head on the bench. I found it to be not too difficult to do in the truck. However getting photo's like this inside the truck is tougher then removing the harness!!
For the record I am not a camera, or video guy. But I try!!
http://youtu.be/YpOfB8jwA_U
I made this quick little video. Mrs DR67 was kind enough to hold the camera.
Hope this will help
Old Dec 7, 2013 | 06:42 PM
Piolet's Avatar
Piolet
Thanks for taking the time to film and post that tip. Reps sent.
tracyclifton
Jun 3, 2012 11:10 PM
jmcotski
Jan 19, 2012 10:08 AM
rickkk
Nov 22, 2011 12:56 PM
normstorm
Aug 18, 2011 08:58 PM
79beater
Dec 5, 2004 11:49 AM
