Dad's Valve Covers
#91
It is time to update this thread re the valve covers for Dad's Engine. There's been a fair amount of discussion on this in that thread, but I'll bring the rest of it over here.
You may/may not remember, but I'm using these valve covers, although the color has yet to be determined.
The problem is that these were designed to use the big wing nuts, and I don't want to use them. In fact, I'm going to use stainless socket-head cap screws (SHCS's). However, on the two holes on the inside edge of each cover the head isn't much larger (.365") than the hole in the valve cover (.3125"), and I don't think that's enough "purchase". Here's how that looks:
Given that, I did a test today. Here's a piece of aluminum drilled .3125" the same as the valve cover and then counterbored .4375":
Here's the screw and a washer turned down to fit:
And, here's the screw and washer in the counterbored hole:
So, that's the plan. The screws and washers are on order and should be in next week. But, I'll wait until they come in to do the counterboring as the heads might be a different height and require a different hole depth.
#92
#100
#101
#105
The CAD drawing was just to show the issue with the diameter of the head and the bore. Sounds like consensus is, as Jim said, just peeking out above the top. Maybe 1/8" or so, and I assume similar to the one I posted above? (I was pleased when I saw it, finished, as the head and washer sit in perfectly, like it was planned that way.)
