Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
What to Replace When Doing Struts/Shocks?
Old Dec 6, 2013 | 12:56 PM
DieselHardware's Avatar
DieselHardware
Planning on replacing the struts and shocks on the wifes 2005 Escape in the near future. What else should be replaced while I'm in there. Plan is to go with OEM parts.
Old Dec 6, 2013 | 03:46 PM
scott91370's Avatar
scott91370
I've done shocks/struts three times and have only done the actual shock. Guess he rubber isolator could be bad but other than that there isn't much else to go bad.
Old Dec 7, 2013 | 10:58 AM
tomw's Avatar
tomw
Take a good look at the sway bar link bushings. Unless they have been replaced with aftermarket, such as MOOG, they won't have grease fittings, and tend to get sloppy over time. When that happens, you get clunking sounds.
It might be easier to do them at the same time as you do the struts. Pretty certain you have to disconnect one end of the link from the strut, so you are only doing one more nut per side.
It would not hurt to check the bearing at the top of the strut for roughness. It bears the weight of the front half of the vehicle, and can, not will, get dry and rough if the lube has been forced out.
tom
Old Dec 9, 2013 | 08:55 AM
DieselHardware
Thanks y'all. Was planning on doing the bearings anyway since they aren't that expensive. I'll take a look at the sway bar links as well.
Old Dec 13, 2013 | 02:15 PM
rickfar's Avatar
rickfar
I replaced both sets of struts on my 2006 and 2008 escape and used the Monroe quick strut all new assembly it was plug and play and if you use the specials at Advance auto you can get the price way down and you are getting new springs, bearings and install is just 6 bolts just MHO
Padlock
Sep 30, 2014 10:20 PM
EconolineFan
Nov 17, 2013 10:12 PM
riverbedjed
Sep 1, 2003 01:10 PM
jeffthom1
Dec 2, 2002 06:35 PM
karcher
Jan 12, 2002 09:28 PM
