no spark need ideas
Old Dec 5, 2013 | 12:24 PM
Twanstyle's Avatar
Twanstyle
no spark need ideas
ok i have gone thru most all the spark issues and no luck figuring out mine
78 300 I6 base
my harness fried and i replaced with the one from bronco graveyard with the help of my local mechanic.
switched out amp gauge for a light in the economy spot, added a ballast resistor according to old ford manual and the new diagram & new plug wires started fine ran ok.
installed new thermostat (found out wasn't running one)
replaced alt belt
ran better
changed thermostat for winter
re-tightened alt belt
ran for a week sat for a day wouldn't start,
have fuel starter makes 1 click noise
so i charged battery,replaced Ignition coil looked like weak spark but was there, cap and rotor seemed a little old, then whole distributor since gear looked warn and was stuck on. next was ignition module.
after all this still wont fire for so looked at first 3 plugs front to back is 1 black 2 more gray black 3 light gray then i drained my oil or should i say my 2stroke mix out of the pan and im stuck on ideas was thinking next thing maybe engine ground strap it looks like its pretty old i didnt notice tll i was pulling filter
Old Dec 5, 2013 | 01:02 PM
fmc400's Avatar
fmc400
MSEE
Sounds like you've done a lot of add-on wiring. Please specify exactly what is connected where.
Old Dec 5, 2013 | 01:15 PM
Dennis snyder's Avatar
Dennis snyder
Have you changed the spark control module . When you change them you have to match the color of the duraspark module cause I ran into that before . I am in the process of restoring a 86 ranger Stx extended cab 4x4
Old Dec 5, 2013 | 01:25 PM
riverguideguy's Avatar
riverguideguy
Originally Posted by Twanstyle
ok
i bet its your starter relay on the fender
Old Dec 6, 2013 | 10:27 AM
Twanstyle's Avatar
Twanstyle
Its not add on exactly its a complete rewire only the voltage regulator and ignition module have the oruginal
Old Dec 6, 2013 | 10:28 AM
Twanstyle's Avatar
Twanstyle
Its not add on exactly its a complete rewire only the voltage regulator and ignition module have the original wire colors
Old Dec 22, 2013 | 05:59 PM
Twanstyle's Avatar
Twanstyle
ok so i got spark finally no wi think i might have broken it
tested spark this morning went to start him up this after noon and bang
sounded like a gunshot under the hood seemed loud for a backfire and not from exhaust
im guessing i didn't get distributor in quite right ?
Bigolferd
Aug 11, 2014 01:14 PM
Eians86f150
Electrical Systems/Wiring
Aug 14, 2013 09:15 AM
ENCLOSURES
33
May 12, 2011 05:42 PM
flo86F1504X4
Mar 1, 2009 06:39 PM
83Ford351M
Aug 3, 2003 12:52 PM
