compression test results what do they mean?
Old Dec 4, 2013 | 08:03 PM
jgilrfr's Avatar
jgilrfr
#1 couldnt get adapter in
#3 250
#5 150
#7 390
#2 330
#4 340
#6 320
#8 300
something tells me this isnt good?it the worst possible time for it ,so with my luck i am guessing new motor time? am i right?
Old Dec 4, 2013 | 08:21 PM
F350-6's Avatar
F350-6
You could always hope you hooked up the adapter wrong or had a bad gauge. I assume with those numbers you're blowby is pretty bad?
Old Dec 4, 2013 | 08:23 PM
jhand124's Avatar
jhand124
#3 250
#5 150
#7 390
#2 330
#4 340
#6 320
#8 300
Was the engine up to temp as much as it can be when tested? #7 is a respectable number. I think you don't want more than a 20% variance. Doesn't look super promising, what led you to want to do a comp test?
Old Dec 4, 2013 | 09:04 PM
jgilrfr's Avatar
jgilrfr
getting p1211 and 1668 codes,just changed injectors and cups and still running rough and making smoke
Old Dec 5, 2013 | 12:39 AM
jgilrfr's Avatar
jgilrfr
yes and the codes and rough idle and smoke,its killin me right now,just did injectors cups starter,front wheel bearings and brakes and rotors and alternator i really dont like this truck right now
Old Dec 5, 2013 | 06:35 AM
Tugly's Avatar
Tugly
...i really dont like this truck right now
I hear ya bud, Stinky put me in a thunk for the longest time... but I didn't have low compression to drive the stake through him.
I have to ask because I didn't know myself - you cranked at least five times on each cylinder to get to peak compression? I'm grasping for hope here.
Old Dec 5, 2013 | 11:51 AM
jgilrfr's Avatar
jgilrfr
i tested them twice and cranked til it wouldnt go any higher got the same numbers,i also made sure the adapter was bottomed out,this is the last news i wanted and i had to be sure.The real bitch of it is this is my only vehicle,i now have no vehicle ,my job is 200 miles away,i am in central NYS near syracuse it is cold (low 30's for highs) we have snow and are getting more and i have nowhere inside to do it.Macnamara's law strikes again.
Old Dec 5, 2013 | 02:04 PM
SteveH-CO's Avatar
SteveH-CO
I would add some oil (2 tablespoons of 10wt. or ATF) and retest (at least the low ones) wet. You may still need a rebuild, but you'll know if it's rings or valves by doing this.
Old Dec 5, 2013 | 02:26 PM
Bonanza35's Avatar
Bonanza35
Really sucks. I must of missed something but why the injector cup change? On the low cyclinders can you here where the air is goings? Pull the oil cap off listen there and in the intake and exhaust. Or is it just leaking around the adapter for the test.
Old Dec 5, 2013 | 03:41 PM
jgilrfr's Avatar
jgilrfr
changed injectors in september and cups went bad in novemeber,problems persisted after cup change which led to compression check
Old Dec 5, 2013 | 03:57 PM
Tugly's Avatar
Tugly
I would get some O-rings with copper washers, pull #3 and #5 injectors (after checking if their torque is good), and pressure test the cooling system before giving up hope on the engine. You just might find a missing copper washer or a couple of loose injector bolts. Stuff like this happened to me a number of times when I thought all was lost. It's 16 bucks and a few hours to try.
Old Dec 5, 2013 | 04:06 PM
Christof13T's Avatar
Christof13T
Eh... 150# on cyl5 is way beyond a missing crush washer.
The rings or cylinder wall is probably toast on #5.
I dont see anything in your sig...
Tuner?
Curious why so many dusted motors are showing up lately.
Old Dec 5, 2013 | 04:48 PM
jgilrfr's Avatar
jgilrfr
just installed dp f6 tuner with new injectors in september changed cups 2 weeks ago,and i did check all bolts immediately before compression test and swapped a different injector to #5 with new o rings and copper washer ,and compression tested twice i am pretty confident the numbers are accurate,the question now is where do i get a new motor?
Old Dec 5, 2013 | 07:41 PM
F350-6's Avatar
F350-6
Junkyard or look at craigslist for someone parting out a wrecked vehicle.
I'd keep it plugged in in the mean time to aid in cold starts. A few drops of oil and re-check the compression is a good idea. If it's rings, you may get by with just a rebuild kit, but 150 is kind of low for just rings.
Old Dec 5, 2013 | 08:04 PM
jhand124's Avatar
jhand124
I used car-part.com to find mine, also got a van turbo, 6.0 intercooler, and my rear axle. It's a national data base for salvage yards. There where quite a few motors on there just in MN and WI. Funny thing is the one everything I picked up can my local junk yard few miles from my house. See if they offer a warranty, mine came with 6 months.
