codes
Old Dec 4, 2013 | 12:22 PM
friskyjake's Avatar
friskyjake
codes
I have a 1987 ranger 2.9 v6 Have a interment ed miss @ idle when warmed up. What is the proper way to pull the codes from the computer, i,st something about counting flashes or lites Thanks guys
Old Dec 5, 2013 | 07:11 AM
pawpaw's Avatar
pawpaw
Check out the "Tech Info" thread atop this forums index page, for instructions on how to pull trouble codes from your OBD-1 system & post All code Numbers, as they can offer up good trouble shooting clues.
Old Dec 6, 2013 | 11:25 AM
friskyjake's Avatar
friskyjake
codes
Thanks Pawpaw I checked the tech pages. No where could I find anything to do with reading ob1 codes or how to even start on anything. Thanks for you trying to help. I,m going to google to if I can find out how to do this.
Old Dec 6, 2013 | 11:51 AM
pawpaw's Avatar
pawpaw
Aw rats, another dead end AOL link in the Tech Info thread, well here is a good link that'll show you what your connectors look like & how to use a jumper wire, test light, or analog multimeter to extract the trouble codes without having to buy a OBD-1 code reader. Fuel Injection Technical Library » How To Run a Self-Test Edit: Here is another link with hookup pictorials. http://www.thorssell.net/hbook/eectest.html
Old Dec 6, 2013 | 12:31 PM
friskyjake's Avatar
friskyjake
codes
Pawpaw --- you are the man [or the other species] Thank you very much Now I will go out & check for the flashing lites. Very good information .Thanks again , Friskyjake
Old Dec 6, 2013 | 12:43 PM
87 XLT's Avatar
87 XLT
Your 87 is not equipped with a CEL, so you'll need to use a VOM or test light to get the codes. Or an Equus 3145 scanner for 25 bucks will retrieve/store/display the codes. No flashing lights to count.
The connector is under the hood hanging at the end of its wires near the heater blower. You'll need to fish around to find it.
Old Dec 6, 2013 | 03:26 PM
friskyjake's Avatar
friskyjake
codes
Thank you fellas for your advice & knowledge . Now if the weather would just warm up a bit. friskyjake
srusse95
Mar 13, 2018 07:41 AM
mudbone1979
Bronco II
Sep 8, 2004 08:24 PM
dogg16
Bronco II
Aug 6, 2004 08:44 PM
cpeterson40
Jul 26, 2004 01:36 PM
acerockola77
Dec 18, 2003 12:40 AM
