Humming noise
Old Dec 4, 2013 | 08:10 PM
RavageX's Avatar
RavageX
My sounds is definitely related to throttle input, If I let off down a hill it mostly goes away and when I romp it it it get really bad.
Old Dec 13, 2013 | 08:17 PM
RavageX's Avatar
RavageX
Ding dong? Any one have a possible solution? Nicmike said pinion bearing could be bad. Could over sized tires cause early bearing wear?
Old Feb 8, 2014 | 09:48 PM
dpslusser's Avatar
dpslusser
I had the truck in the garage 2 weeks ago for an oil change. I told the mec to give it another shot trying to find the noise. While he was in the pit popping the drain plug he noticed something on my passenger front tire. The inside tread, about 1 inch wide, was darker than the rest of the tire. He lifted the truck up in the air and spun the tire by hand. He could only get the tire to make a 3/4 rotation without stopping. He had to rotate it the rest of the way through and could then spin it another 3/4 spin. After locking the hub in and out he realized that the hub wasn't unlocking fully and the shaft was spinning. He checked the other side and it was spinning freely with the hub unlocked. Here I had a bad hub. The mechanic thinks the noise is def tire related since the sticky hub messed the tread up on the that one tire. I haven't replace the tires yet to see if that is true or if my gas mileage came back.
derail01
Feb 2, 2017 11:28 AM
dieseldrew
2009 - 2014 F150
Oct 21, 2015 12:21 AM
caprang
Jun 7, 2011 10:36 PM
Shade
Aug 20, 2008 02:03 PM
grizzly041771
1997 - 2003 F150
19
Jun 26, 2008 08:48 PM
