2002 Excursion Lift
Dec 3, 2013 | 08:28 PM
2002 Excursion Lift
I'm planning to install a leveling kit on my 02 Excursion. I was thinking of using this kit 2.5" kit:
http://www.summitracing.com/parts/SUM-G782/
I'm wondering if I can run 35" tires with this kit. Has anyone else run 35" tires with a 2.5" leveling kit?
Also, was wondering if anyone has ever experienced any vibration issues with the U-joint, after doing a leveling kit?
Dec 3, 2013 | 09:49 PM
Dec 3, 2013 | 11:34 PM
Quote:
Originally Posted by
jonezzzman
Lotta money for a few leafs when you could pick some up at a spring shop plus it will ride rougher.
Dec 4, 2013 | 12:04 AM
I ran 35's (315/75/16) on only 1" of front lift/leveling.
mine also rubbed the inner rear edge of the leaf springs
Dec 4, 2013 | 12:07 AM
wpnaes
Jonez,
I ran 315s for years with a 2 inch level kit ($99)....
What leveling kit did you use? Do you remember? $99 seems like a pretty good price!
Dec 4, 2013 | 12:37 AM
Tylus
Were those on 7" wide wheels and did they wear in the middle. How did you like them?
Dec 4, 2013 | 12:55 AM
EXv10
still have those tires installed. just lifted the X 2" higher
the tires fit perfectly IMO. No wear issues that I've noticed. keep them inflated to 50 psi and seems to be good. I will be going to a 305 width next time though. the rubbing on the leaf springs if freaking annoying, but otherwise love the size
Dec 4, 2013 | 07:49 AM
Something like this....
http://www.ebay.com/itm/99-04-FORD-F250-2-8-Front-Leveling-lift-kit-F-250-/220730665767?pt=Motors_Car_Truck_Parts_Accessories&hash=item336492ab27&vxp=mtr
http://www.ebay.com/itm/F250-F350-Ford-Super-Duty-Excursion-2-Front-Lift-Shackle-Leveling-Kit-/121226867723?pt=Motors_Car_Truck_Parts_Accessories&hash=item1c39af340b&vxp=mtr
Dec 4, 2013 | 10:52 AM
wpnaes
Those top ones are expensive, do nothing for bumpstop clearance and are probably even dangerous.
delifresh
2009 - 2014 F150
May 16, 2020 12:28 PM
Ecarlton1991
Aug 23, 2011 03:22 AM
wedge88
Sep 11, 2009 01:06 PM
Still Smoking
2004 - 2008 F150
Jun 27, 2008 05:04 AM
