Hey guys, im looking at a set of SD axles for my 92 F250. I have been looking for the last 2hrs and have found measurements for seemingly every axle in exsistence except for the SD D50/60.
If someone could tell me what the center to center width is on the spring pads of the front axle i would REALLY appreciate it. Wouldnt hurt to know the same measurment for the rear either.
Also, a bit more trivial, but still need to know, if anyone can tell me the size and taper of the draglink joint that goes in the pittman arm.
I can check when I get home for spring spacing. I have no idea how to measure the drag link. I have a 2002.
