Engine ID
Old Jun 23, 2003 | 08:52 PM
packratt's Avatar
packratt
Trailering
Engine ID
I have a 1979 F-600. When I bought the truck I was told it had had a 460 swapped in to replace the stock 370. The valve covers say it is a 370. Without tearing the motor apart is there any easy way to ID which motor it is? I need to get a vacuum advance for the distributor.
Also what are the timing specs for a 79 460 and 370. I don't have any info for the 460 and the sticker is barely readable if it is a 370.
Thanks
Le
Old Jun 24, 2003 | 04:23 AM
ludis's Avatar
ludis
Engine ID
What are the casting codes on the block and heads?
Old Jun 24, 2003 | 07:57 PM
packratt's Avatar
packratt
Trailering
Engine ID
Where are the block codes located? I'd like to avoid pulling the valve covers if possible.
Le
Old Jun 24, 2003 | 09:53 PM
airharley's Avatar
airharley
Engine ID
Look above the starter. You may need to use a wire brush to knock the gunk off of it to see it.
Old Jun 24, 2003 | 10:27 PM
packratt's Avatar
packratt
Trailering
Engine ID
What should the codes be for 460 and 370?
Thanks
Le
Old Jun 25, 2003 | 12:27 AM
Mil1ion's Avatar
Mil1ion
Engine ID
Ona 460 the numbers are just above the sparkplugs on the edge of the heads.
Probably D8VE-??
Old Jun 25, 2003 | 08:20 PM
packratt's Avatar
packratt
Trailering
Engine ID
The code on the block above the starter is
B9TE-BB
The first character was hard to make out but it appeared to be a B.
Intake D9TE-EA
Could not find head codes
370 valve covers bolt up to the heads and it took 8-1/2 quart of oil for the oil change.
Old Jun 26, 2003 | 02:20 PM
wtroger's Avatar
wtroger
Engine ID
It must be D9 on the block a B9 would be 1959 engine code D9 means block designed 1979
Old Jun 26, 2003 | 03:01 PM
Mil1ion's Avatar
Mil1ion
Engine ID
Well if there aren't any codes on the heads where I said that isn't a 460.
Now, Because it was designed in 79, I would say it is a another version of a 351M or 400
How many valve cover bolts are there ?
Old Jun 26, 2003 | 06:12 PM
packratt's Avatar
packratt
Trailering
Engine ID
Considering it is considerably bigger than any small block I've ever seen including the old Chrysler 318 polysphere (wide blocks) I don't think it is a 351M or 400.
I also am certain it is not a FE.
There are 7 bolts holding the valve cover on.
No codes under the valve covers except for the standard mold numbers. The only thing unusual was a large M over a C within a C. I went over the sides of the heads with a mirror, It's a little hard to stand on the bumper and hang upside down to get a direct look at them, and there were no stamps on the side of the heads. If there were any on the ends they are behind the brackets.
For all I know they are not stock heads. The person who supposidly swapped motors has done some hotrodding in the past. He may have used a motor he had on hand with aftermarket heads.
Le
Old Jun 26, 2003 | 09:27 PM
airharley's Avatar
airharley
Engine ID
Here's one for you. Is it possible it is a 430 or 462? I haven't seen one in a while but it is a possibility with a B9TE casting code.
Old Jun 26, 2003 | 09:33 PM
airharley's Avatar
airharley
Engine ID
OK I stand corrected. I ran the casting code through google and it came up with a 391 FT motor. Figure that one out.
Old Jun 26, 2003 | 09:35 PM
Mil1ion's Avatar
Mil1ion
Engine ID
That's where I was heading once you replied with valve cover bolts.
The 391 was used in 79
Old Jun 26, 2003 | 09:44 PM
packratt's Avatar
packratt
Trailering
Talking Engine ID
I thought I posted this an hour ago. It must have gotten lost in the e-mail.
The motor is actually a 370. The original owner had a 460 that he was going to swap in but didn't. What I got from the person I bought the truck from was that it had been swapped.
Thanks for all the help.
Le
