oil
Old Dec 2, 2013 | 01:36 PM
720Deere's Avatar
720Deere
I use the 15w40 Premium Blue in the Summer and 5W40 Premium Blue Extreme in the Winter. As expensive as it is, the 5W40 shows the best performance overall but especially as it relates to regen frequency.
Old Dec 2, 2013 | 09:30 PM
Jus2shy's Avatar
Jus2shy
Originally Posted by 720Deere
The number one reason to use the Valvoline is that it is Cummins approved. If the holy grail of diesels approves of it, it has to be good stuff. After all, people have bought hundreds of thousands of Dodge trucks just because of Cummins, right?
HEY! I resemble that remark!
Old Dec 2, 2013 | 11:03 PM
McFarlandkm's Avatar
McFarlandkm
I'm a fan of the AMSOIL products. Started using it in my Harley and boat. Changed the diesel over at 15k. Get the oem 5w40 for about 90.00 for 3.5 gallons. After 1500 miles is appears cleaner/clearer than motorcraft did.
Old Dec 4, 2013 | 06:01 PM
XXLTexan's Avatar
XXLTexan
I'm about to get my first oil change. It looks like the Valvoline Blue and Extreme Blue seem to be the favorites on this thread. I have noticed three different weights. 5/40,15/40, and even 10/30 mentioned (Not all Valvoline). So can someone tell me which weight is the best? I live in north Texas so it's as hot as it gets some of the time, moderate some of the time, and cold with some freezing for two to three months a year. Thanks in advance.
Old Dec 4, 2013 | 06:28 PM
Romeo Scorpion's Avatar
Romeo Scorpion
In a hot climate like yours 15W-40 will work fine. The important number here for hot climates is the 40. 15W-40 is significantly cheaper than 5W-40. 5W is best in real cold climate areas, like what I see here in Michigan.
Both Valvoline Premium Blue products use dispersive polymer technology (DPT), with premium Group II base oil for better soot control (reduces active regens).
Old Dec 5, 2013 | 05:07 PM
XXLTexan's Avatar
XXLTexan
So 15/40 is cool even in the winter months? It gets into the teens and that about it. Thanks again!
Old Dec 5, 2013 | 05:26 PM
720Deere's Avatar
720Deere
If you go by Ford's recommendations, 15W40 is only suggested down to like 30* (that may not be right), but it can be used. If you are going to run 15w40 in the teens, let the truck warm up for a minute or two before you go out and romp on it. 10w30 or 5w40 is recommended in freezing temperatures.
Old Dec 5, 2013 | 07:09 PM
6.7 & 1966's Avatar
6.7 & 1966
at what intervals do you guys change the oil? Thanks
Old Dec 5, 2013 | 07:19 PM
kper05's Avatar
kper05
I used 15w-40 for three winters in my truck.
The coldest was 8°F, I just let it warm up for awhile.
Down here though, even if it's that cold in the early morning, it's usually above freezing by lunch so I never saw it as much of a concern as long as I take it easy.
It's only that cold for a few weeks, anyways.
Old Dec 5, 2013 | 07:31 PM
McFarlandkm
When the Nanny says to!
Old Dec 5, 2013 | 09:12 PM
Tofan's Avatar
Tofan
I change my oil every 5000 miles!
Old Dec 6, 2013 | 11:52 AM
sgrol's Avatar
sgrol
The way this occurs seems to be through the PCV system. Gasses from the crankcase/oil are routed into the intake for combustion, where they apparently create something that loads up the DPF. I discovered or should I say confirmed this accidently.
So why not do a PCV reroute like we did on the 7.3s? Keep the crankcase crap out of the intake and turbo and cut down on regens at the same time. I looked into my intake and could see traces of oil coming from the PCV inlet to the intake. On the downside, if the PCV system breathes in and out, a reroute may introduce contamination to crankcase by inhaling unfiltered air. Just thinking out loud.
Old Dec 6, 2013 | 01:12 PM
  #28
Romeo Scorpion
I've given that some thought but haven't had the time to follow through with it. What you pointed out is a big concern of mine. Besides, coating the inside of the intercooler with a film of oil certainly isn't going to help its efficiency.
BTW, it may breathe in a little after the engine is shut down and begins to cool off, but while its running the crankcase definitely shows positive pressure.
Bohen
6.7L Power Stroke Diesel
Oct 3, 2016 06:01 PM
Ford11
Sep 18, 2014 02:06 PM
pmoney1983
Nov 11, 2011 06:37 PM
rm2092
2004 - 2008 F150
Sep 28, 2008 09:32 PM
RdBaron03
Jun 29, 2003 02:12 PM
