Carburetor installation
Old Dec 1, 2013 | 11:56 AM
DieHardChief's Avatar
DieHardChief
Lightbulb Carburetor installation
Hey guys, I changed out my old carb with a rebuilt replacement from National. I got everything cleaned up and old parts replaced...EGR valve, Vacuum ported switch, new fuel filter, thermostat...
I got all the vacuum lines hooked up, linkages are in place.
Truck wont start. Im thinking fuel.
Im thinking its a fuel issue. Should I spray some starter fluid in carb?
Are there anything I missed to do once I put a new carb in to get fuel flowing? This is my first time so figured Id ask some experienced guys first...
thanks.
Old Dec 1, 2013 | 12:06 PM
Jklnhyd's Avatar
Jklnhyd
Are you getting gas to the carb?
You need to dial it in to your truck, air/gas mixture, idle, etc. Its not just "plug and play"
Old Dec 1, 2013 | 02:10 PM
fmc400's Avatar
fmc400
MSEE
Why is that? Have you checked for fuel? What evidence is behind your claim?
Old Dec 1, 2013 | 02:17 PM
rlb652_674's Avatar
rlb652_674
Go ahead and spray some starter fluid down the carb if you have not already. If you are getting fuel to the carb most likely the floats are a touch sticky and the fuel bowl is not filling up. Had it happen with mine and getting it running helps with that. More fuel flowing. Sometimes they come with the floats stuck. I have been lucky there - was able to take the carb off, turn it upside down and tap the bowl (and gently shake the carb) until I heard them moving.
Once you have it running make sure you have no vacumn leaks. Then you have to adjust the air/fuel mixture and idle. You can read up on using a vacumn guage to adjust these - I just adjusted idle to approx 700, adjusted the air/fuel for the highest idle, backed it down a quarter turn and re-adjusted the idle if needed.
Good luck!
BMaeder1
23
Jul 18, 2019 01:23 PM
78 Ford F150 460
1978 - 1996 Big Bronco
20
Dec 15, 2016 07:02 PM
mikemustang289
Aug 14, 2011 10:40 PM
PaulzF150
19
Aug 28, 2007 02:45 AM
hotbbb
Jan 30, 2004 11:55 AM
