Charcoal Canister question
Old Nov 30, 2013 | 04:53 PM
IDIDieselJohn's Avatar
IDIDieselJohn
And once again, my piece of crap '94 F150 300-6 is giving me problems. Luckily this time, it's minor
Few weeks ago I resolved oil and coffee puking out my crankcase breather tube. Well that lasted up till few days ago, it started puking out oil and coffee again.
But also, noticed the engine would rev up to 1200RPM by it self once in a while.
I taught ok, maybe vacuum leak, causing the PCV to not work properly....and so I was right.
Started lookin around, and what do you know, noticed my charcoal canister (tomato can thing on inner fender) was rotted through.
My question is, I know that's for emissions, but do I really need it?
Can I just remove it, and cap off those vacuum lines going to it??
Old Nov 30, 2013 | 05:14 PM
subford's Avatar
subford
That is not a charcoal canister, it is a vacuum tank.
You need it for when the the engine vacuum is low (WOT) to keep the emissions devices working.
Some do.
Old Nov 30, 2013 | 05:27 PM
IDIDieselJohn
Well that explains alot! Thanks!
I'l check what the one in my parts '95 truck, if it's not in good shape, i'll get a new one.
Tell me something though....hope it's not a dealer only thing?
Old Nov 30, 2013 | 06:01 PM
warren561's Avatar
warren561
My 96 has a oval shaped vacuum tank. Its a three legged thing that looks like this (P/N 4C3Z-9E453-AA):
http://www.ebay.com/itm/BRAND-NEW-FORD-OEM-EGR-EXHAUST-GAR-RECIRCULATING-VACUUM-RESERVOIR-4C3Z-9E453-AA-/261095010015?pt=Motors_Car_Truck_Parts_Accessories&hash=item3cca79aedf&vxp=mtr
I've seen a coffee-can style tank in the same body-style trucks. I'm guessing they switched tank styles in 92 or 93 or 94?
I don't think the coffee-can style tank is still available. But, you can make your own:
Couldn't find a vacuum reservoir, so.... - Diesel Forum - TheDieselStop.com
Old Nov 30, 2013 | 06:17 PM
Evan_P's Avatar
Evan_P
LMC sells both styles. I personally would not put another metal one in. Find one of the plastic reservoirs. I got mine of a JY 96 F150.
Old Nov 30, 2013 | 06:22 PM
IDIDieselJohn
Was the newer plastic ones at the same location as the old metal ones on the passenger side inner fender?
Old Nov 30, 2013 | 06:23 PM
IDIDieselJohn
I might actually just make one like that link if I can't find one.
Old Nov 30, 2013 | 06:35 PM
Evan_P's Avatar
Evan_P
Yes it will. In fact, mine already had the holes for it in the inner fender.
Old Nov 30, 2013 | 07:35 PM
rla2005's Avatar
rla2005
X2...my old 1992 F350 had the plastic dual vacuum reservoir in the same location.
Old Nov 30, 2013 | 07:54 PM
Krisverde's Avatar
Krisverde
I put a newer one in my 91. 2 of the holes lined up and the 3rd leg did not. So I just broke it off.
Dusty Wooddell
1983 - 2012 Ranger & B-Series
Oct 15, 2011 07:37 PM
xc4jokestomper
Nov 11, 2010 04:48 PM
marcus02PSD
Nov 15, 2008 08:18 PM
hugepettyfan
1997 - 2003 F150
Oct 21, 2005 06:43 PM
CMHaas
Jun 2, 2004 09:27 PM
