F3 frame measurement needed
Old Nov 30, 2013 | 12:59 PM
aussiecowboy's Avatar
aussiecowboy
I never noticed it before, seeing as my truck had a home made flat bed when I got it, but at some point in the past someone has cut the last 12 to 15 inches off the rear of the frame rails. I only found it when I was starting to measure up to install the express bed.
So, what I'm looking for is a total frame rail length and some pictures and details of the rear most crossmember and where the bumper irons bolt on. Can anyone help?
I can't find a junk frame to cut up so I'll need to fabricate everything, I want to run a tow hitch also so I'll need to build it strong.
Thanks
Old Nov 30, 2013 | 03:02 PM
oldmerc's Avatar
oldmerc
oldmerc
See if these help . The holes are where the wooden box cross rails bolted through to the frame .
Old Nov 30, 2013 | 03:27 PM
truckdog62563's Avatar
truckdog62563
Marmon-Herrington Man
Allan's got you covered, but here's some more pics. The total frame length is 17 feet. I'll also post a close up of the bumper bracket holes. Stu
Old Nov 30, 2013 | 03:51 PM
aussiecowboy
That's brilliant Allan and Stu, exactly what I was after, thanks. Not as much missing from mine as I thought, only about 7 inches by the look of it. I had assumed there was another crossmember at the back but not so. I might have to pull that crossmember out so I can fish plate the rails from inside and then trim it to fit and bolt it back in.
ralphhood3
Feb 22, 2011 12:33 PM
brettdacosta
Jun 1, 2010 04:12 PM
randrford
Sep 9, 2009 07:54 PM
19704X4F250
1983 - 2012 Ranger & B-Series
19
Jul 27, 2009 07:03 PM
Uncle JT
Nov 27, 2002 06:40 AM
