replacing '93 e150 radio
Old Jun 23, 2003 | 06:26 PM
dren476's Avatar
dren476
I've removed about 20 screws from around the console, but there must be some hidden screws, cuz the panel surrounding the radio and instrument panel wont budge. Any suggestions on where the hidden screws are?
Old Jun 23, 2003 | 08:29 PM
mikeindmills's Avatar
mikeindmills
go to your local parts store, and buy the Ford radio removal tools. they look like two small horseshoes with barbs on the end. find the holes located at each corner of the radio, and insert the tools. push in towards the center of the radio, once the barbs are in place, and pull out. if its the old old style radio, there is a screw on both sides that holds the bracket on..these are easily missed, not to mention a pain once you find them.
Old Jun 24, 2003 | 02:17 AM
pfogle's Avatar
pfogle
You have to remove the cupholder assembly, as well as the 2 screws angled up abaove the speedo cluster. then gently pull the panel to remove the clips. Put the key in turn it to the off position ,put in gear, and gently remove trim. Then cut the long bar out of a WIRE coat hanger into 2 pieces and bend them to make 2 "U" shaped pieces, insert them approximatly 1/2 inch into the holes on the radio, gently push them towards the middle of the radio, and pull at the same time. If done correctly the factory radio will slide right out.
GN1220
Oct 6, 2016 10:14 AM
Toppa
Jul 20, 2016 06:45 AM
chris starscream
Oct 9, 2015 09:12 PM
884x4broncoII
15
Sep 24, 2008 08:06 AM
tommytorino
1997 - 2003 F150
Sep 26, 2007 04:38 PM
