Sponsored by: Real Truck
Airbag Light Flash Code (LFC) #19 question...
Old Nov 29, 2013 | 04:07 PM
downhomer's Avatar
downhomer
On my 09 F250 my airbag light flashes once, pause, 9 times for a error code of 19. Then it is supposed to stay on. Sometimes it stays on for a week or more. Sometimes it will randomly come on or randomly go off. There is no fixed sequence of the events. Sometimes I'll get the #19 code flashed 3 times but the airbag light doesn't stay on. Took it to the dealer and as I pulled into parking lot it went off. Service tech said he couldn't read a diagnostic code since light wasn't on. I thought there would be a history file stored? Code #19 is indication that the Restraint Control Module data is full I believe. However, it was full it should stay lit right? I'm beginning to wonder if there's a software issue or a ground issue? No problems with cruise control or horn. Anyone have any ideas? I'm at a loss for why it happens so randomly. Service tech reseated all connectors under the seats but hasn't made any difference.
Old Jan 10, 2014 | 02:55 PM
downhomer's Avatar
downhomer
Update
Problem finally solved. Turned out to be the clock spring after all. New one installed by dealer, just before warranty expires!
NW 150
Aug 13, 2013 07:59 PM
Andrew R
1978 - 1996 Big Bronco
Dec 15, 2008 08:40 PM
purrfactor
1983 - 2012 Ranger & B-Series
Jul 16, 2004 12:27 PM
bronco up
Jan 25, 2004 08:21 PM
