6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
MY COOLANT PROBLEMS CONTINUE, DAG GUM IT !!!!!
Old Sep 16, 2014 | 11:27 AM
  #46
StanleyZ's Avatar
StanleyZ
Originally Posted by GHeTTo JOe
just looking at the two tanks, if using the old tank would moving your small return hose to the top and block the lower port on the tank give the same results as a the new updated tank? or do you think you need the head space of having less coolant in the tank?
Would not have mattered what I did, I had a blown Head Gasket. Then after I got that squared away I got hit and the truck was totaled.
Old Sep 16, 2014 | 12:29 PM
  #47
73fan's Avatar
73fan
Sounds like Murphy's law! What a bad deal. I feel for you.
Sent from Nexus 4. IB AutoGroup
Old Sep 16, 2014 | 02:32 PM
  #48
StanleyZ's Avatar
StanleyZ
Well, the HG was mny fault. Had a senior moment and forgot what tune I was on. The wreck was 100% the drunk woman's fault. I'm still dickering with the insurance company but I think in the end I'll be OK. No one hurt seriously and I got a new 6.7 replacement. Now, if they will just pay for it everything will be OK.
Old Sep 27, 2014 | 08:43 PM
  #49
studdard's Avatar
studdard
I have the same problem with my 08 just spent $4000.00 at dealer trying to fix this truck and not fixed yet
Old Sep 28, 2014 | 08:29 AM
  #50
StanleyZ's Avatar
StanleyZ
You know it's funny. I had mine to two different ford dealers during my attempts to solve the riddle, neither even suggested HGs could be the problem. I was out of warranty and the tuner was on the truck so I don't think they were dodging a warranty claim. But both were experienced techs and it surely must have occured to them that it might be a blown HG. I sure thought it was, but it took a while to prove it.
I don't know what part of the country you are in but Bill Hewitt's Power Stroke in buford Ga (just north of ATL) is a cracker jack outfit. All they do is Ford power strokes. You can look them up at powerstrokehelp.com they have a whole series of videos on you tube.
If your truck is like mine it can be driven for a good while, just keep coolant in it. mine would only puke when worked hard. Bill will fix it right, it won't be cheap but it will be fixed.
Old Oct 25, 2014 | 08:29 AM
  #51
yiannis50's Avatar
yiannis50
check oil temp
If you want the history see my threads from October. Short story is I am still losing coolant. I've tried two different Ford dealers and neither was able to solve the riddle.
I hooked up the trailer and headed for Mississippi on wed morning. It was cold but otherwise a routine trip. About 50 miles or so into the trip I stopped at the Alabama welcome center. just for grins I checked the hood and sure enough there it was, coolant puke on the degas tank. So, I continued on, checking a couple times along the way. Truck did not get hot (200 degrees or so), just like last time. I found no signs of external leaks. Truck ran and towed great. No codes or lights. Had I not opened the hood and looked I would have not known I had a problem.
At each stop I found the coolant had receded to a level just above the small return hose. When I loosened the cap the pressure would release and the coolant would rise to a normal looking degas level. I believe that prior to this problem starting the hot coolant level was up near the top of the degas tank.
Today it took 24 ounces or 1.5 pints to raise the cold coolant to the normal level. I lost that in 300 miles or one half pint each 100 miles. I went back and checked ant that is the same rate of loss I experienced last summer/fall.
Other factors bearing on the problem.
All external leaks have been repaired
No coolant in oil ( Blackstone)
I tested for exhaust in coolant, test was negative.
No white smoke.
No coolant visible in tranny fluid.
Coolant system will hold 16 PSI for 6 hours or more but not overnight.
I am open for suggestions. Thanks
get scangauge 2 and monitor oil temp vice water you may have a abd oil cooler, plus cavitacion on the water pump cover
Old Oct 26, 2014 | 09:30 PM
  #52
StanleyZ's Avatar
StanleyZ
Nah, this is an old thread. Truck had blown head gasket. Cost me 5500 bucks or so, then a month later I got hit and the insurance company called it a total.
RigCity
26
Apr 3, 2019 05:57 PM
96blackford
13
Jul 30, 2013 02:24 AM
mstiles19
Feb 25, 2013 04:59 PM
capt caper
97
Oct 19, 2012 12:36 AM
