Early 2004 low power while cold. Thinking it's injector o rings or injectors. Little smoke until warm. FICM just under 48 volts while cold. ICP and IPR look good. Any ideas?
It's not my truck so it's hard to say if it adds fuel. How can I test for dilution? Little smoke comes when it's very cold around 20 degrees. Your post is what made me think o rings first
What specifically would be the failure in the injector if the power balance is almost completely flat? See o rings being a fix for 7.3l for similar problems.
So the HP oil doesnt seal with an o ring? If the o rings are bad it'll add fuel to the oil and there won't be enough fuel pressure until it warms up and the o ring seals?
Top image is the injector before I cleaned it compared to a clean one. Bottom image is after I cleaned the injector. The streaks look like fuel eating out the metal? Are these injectors salvageable?
P.S. That black gunk smelled strongly of fuel which makes me think I was on the right track with o rings.
