voltage at fuel pump question.
Old Nov 29, 2013 | 05:54 PM
sccamper's Avatar
sccamper
Turning the key to run only supplies power to the pump for a second, This primes the system. 12 volts returns when you go to crank position, or turn key off and back on(then power for a sec). When you turn key to run, get 12v then it drops, Im not sure if you should get 4v or 0v. If the pump runs when you supply power from another source but not when it 12v from vehicle, you need to check how many amps are getting to the pump. 12 volts on a gauge is worthless if it doesnt have any amps getting to it.
Old Dec 8, 2013 | 07:32 PM
10fords's Avatar
10fords
To update- I replaced the pump today and all is well!! Thanks to all who replied- Scott
ET1993Ford
Dec 24, 2023 10:13 AM
Onus
Sep 20, 2011 06:14 PM
jimlahey
Aerostar
Oct 9, 2005 01:53 PM
mattklionsky
Electrical Systems/Wiring
Aug 4, 2001 01:17 PM
mattklionsky
1997 - 2003 F150
Aug 2, 2001 11:00 PM
