Fixed fuel pump
Old Sep 20, 2011 | 02:51 PM
Onus's Avatar
Onus
Fixed fuel pump
Had some free time today as one of my classes was canceled and decided to do some digging. Checked the wires running back to the tank and they all seemed good and solid, so that can't be the issue. I jumpered two of the eec pins together to keep the fuel pump on the whole time the key was on (pins e and a). This would help in my trouble shooting. I then went to the roll over switch and pulled out the connector, reason being i can test the voltage coming from the relay. Other than the relay it would be the fusible link which was good as we had spark. One of the wires was zero off zero on so it must be the output wire. Next one was zero off .34 volts on. Humm .34 volts i don't think that will run a fuel pump not sure what you think. Ran out a got a new relay at napa plugged her in. Primed the pump 5 or so times and fired her up, she stumbled a bit but she caught (tank has bad gas too). As dave from daves farm says "She lives to die another day" I hope this can help people out with a similar problem. Multimeters are you best friend.
Old Sep 20, 2011 | 05:57 PM
73FOMO's Avatar
73FOMO
Glad you got it fixed....about the only way to tackle electrical issues.
Old Sep 20, 2011 | 06:14 PM
Onus's Avatar
Onus
Crack out the multimeter and go searching.
Dillweed73
Mar 8, 2017 09:12 PM
MrT
29
Mar 31, 2006 05:47 PM
Ed_B1
Electrical Systems/Wiring
Sep 28, 2003 07:16 PM
sheik
Aug 2, 2001 10:54 AM
