Need help
Old Nov 27, 2013 | 05:57 PM
tbugher62's Avatar
tbugher62
Need help
Hi guys,I have a small problem with my 94 f350 4x4 ,7.5 , 5 speed tranny,my problem is that when I am make a sharp turn like pulling into a parking space,or backing out and making a sharp turn either way the truck kinda vibrates like something is binding im at loss as to what it could be.So any ideas ? the tires are not hitting anything so thats not it.
Old Nov 27, 2013 | 06:40 PM
Fords4Me's Avatar
Fords4Me
Hubs locked maybe?
Old Nov 27, 2013 | 06:43 PM
eakermeld's Avatar
eakermeld
If you have lug-type tires, it could just be the tires cambering up in a tight turn. That's nothing to worry about.
Old Nov 27, 2013 | 07:50 PM
tbugher62's Avatar
tbugher62
Hubs are not locked,it feels like a gear or bearing is twisting upon turning ?
Im going to see if it still does it if I take it out of gear going into the turn.
Old Nov 28, 2013 | 07:15 AM
Fords4Me's Avatar
Fords4Me
Only other thing coming to mind is wheel bearings or loose lugs. There just isn't much more there.... tires, lug nuts, brakes, hubs and bearings. tight turns can also make brakes drag a little from the play in the wheel bearings.
Old Nov 28, 2013 | 09:55 AM
tbugher62's Avatar
tbugher62
Thanks guys ,I will check all your ideas out.
Old Nov 28, 2013 | 08:08 PM
86f250hd's Avatar
86f250hd
Sounds like it could be the power steering pump does it do it not moving lock to lock steering
Old Nov 29, 2013 | 11:22 AM
tbugher62's Avatar
tbugher62
I was thinking it could be the power steering pump is going bad,it does it only on extreme turning,so im thinking the pump is at its most pressurized time at that piont,I checked the wheel bearings and lug nuts they are not the problem as both are nice and tight. One more thing my truck doesnt have a steering stabilizer on it ,so I dont know if that hurts the steering or not.
cabloom300
Feb 11, 2015 11:51 PM
Trojan8975
Feb 28, 2012 09:25 PM
Dyllan78
Jan 30, 2011 02:59 PM
Wakeboarder141
1978 - 1996 Big Bronco
15
Feb 18, 2005 06:47 PM
Thomasm67
Kansas Chapter
13
Jan 9, 2005 12:17 PM
