Replacing Fuse Block
Old Nov 26, 2013 | 05:52 PM
boonslick's Avatar
boonslick
Good evening guys!
I have a 1987 F150 5.0L E4OD 2WD XLT Lariat Standard Cab.
A while back the ears broke off the Fuse Block and I want to replace it. However, it is unique as not only does it have a Flashing Relay in front it has another Flashing Relay hidden on the back almost the same location as the front.
I have yet to see one like it at the boneyard.
I got one to experiment with and pulled hard on the wires on the back to no avail.
How are they attached?
Has anyone ever changed out the Fuse Block?
Do I have to use the entire loom and replace each wire one at a time?
Thank you!
Boon
FedEx Driver
Apr 6, 2014 07:15 PM
29abone
Electrical Systems/Wiring
Jan 20, 2009 07:38 PM
TRTundra
Mar 19, 2003 09:08 AM
