The stereo in our 2004 Eddie Bauer Expedition has broken. The CD player keeps giving errors and want play a CD. I want to install an aftermarket radio and haven't been in that scene in many a year. What brands are worthing having these days? What brands have you guys used that you liked? What fits well? I plan to purchase a double DIN size. How well do the steering wheel controls work with an aftermarket radio?
Crutchfield will tell you they don't have a double DIN to fit the space. The folks here who have done radio work have to do some cobbling to make it fit properly and look good. The other threads on this topic discuss an add on that allows the steering wheel controls to work.
Did you tell them it was for an 04 Expedition? I've had the conversation with them twice and gotten nowhere. Does this then take the changer in the console out of the mix or can you integrate it?
Ah, the difference must be in the navigation head unit - with factory nav you got the changer in the console. Interesting if you select a 2004 without factory nav you wind up with a group of double DINs to choose from, including some with nav. If you select a 2004 with factory nav you get no choices.
It's a nice opportunity to upgrade it to a nav system. Crutchfield has the trim kit that makes it look factory. It's the exact same amount of work to do a nav system as it is to just do a stereo installation. The GPS antenna just goes behind the head unit on the support beam of the dash, hidden out of sight. The GPS signal passes easily through the windshield and dash cover. I installed a Pioneer unit in mine by myself, no problems at all.
