Need help
Old Nov 25, 2013 | 07:57 PM
Tyler Grey's Avatar
Tyler Grey
Need help
Hi guys. I just bought my 1970 F-100 sport custom 2 days ago. I'm new to these trucks and don't know much about them. The heat stopped working. About every second or so the truck clunks. It's hard to find 3rd gear (it's a 4 speed) anybody know what those things might be?
Old Nov 25, 2013 | 08:18 PM
HIO Silver's Avatar
HIO Silver
Congrats on your new ownership.
Besides turning on the ignition and putting gasoline into the tank, how much have you tried to learn about your truck? You have to start somewhere and posting your symptoms without any troubleshooting on your part is, well, rather lame.
Have you looked under the hood to see if the heater valve cable slipped off? What about checking the heater cable at the controls? Still connected? What about the coolant level?
"Clunks". Under what circumstances does it happen? Shifting into gear? Turning? Stopping? Do you feel the clunk or can you just hear it?
Gears... check the lubrication level? What transmission do you have? Does it happen all the time or only when hot or cold?
I'm busting your ballz because YOU have to have some skin in the game and to be your own detective. Be inquisitive but be smart about it... posting your very vague questions without any background info or actual work on your part does no one any good except us waste time guessing at your issues.
Old Nov 25, 2013 | 08:25 PM
Tyler Grey's Avatar
Tyler Grey
Well the clunk i can hear and feel when i'm driving down the road. I'm new to all of this and I don't know where a lot of it is. I'm going to pick up a Chilton's catalog for this year hopefully soon. The heater was working just fine and then it started just blowing out cold air. Maybe it's the core or maybe one of the hoses are clogged. I'm just seeing if anyone is having the same issues or has had them in the past. The transmission was originally an automatic but was converted to a manual. It has a Mercury 390 V8 in her.
Old Nov 25, 2013 | 08:32 PM
Tyler Grey's Avatar
Tyler Grey
I do know it needs a new exhaust manifold gasket and tie rod ends.
Old Nov 25, 2013 | 08:35 PM
HIO Silver's Avatar
HIO Silver
Crawl (eegads?) under your truck and wiggle the driveshaft to check for loose or worn u-joints. In fact, grab and wiggle everything under there to check for integrity. It might just be the exhaust system rubbing against something.
Check the heater valve and cable I mentioned above. That does of course require opening the hood...
Learning curve ahead!
Old Nov 25, 2013 | 08:37 PM
Tyler Grey's Avatar
Tyler Grey
Okay i'll do that when I get the chance. And I know I have to open the hood
Old Nov 25, 2013 | 08:38 PM
JWC 3's Avatar
JWC 3
First thing to check on the heat issue ,,, Coolant level . I see it often , low coolant no heat .
Old Nov 25, 2013 | 08:42 PM
Tyler Grey's Avatar
Tyler Grey
The radiator does have a slow leak so would that maybe have something to do with it?
Old Nov 25, 2013 | 08:46 PM
yetiman38237's Avatar
yetiman38237
only if coolant level drops below the neck then it cant circulate through the heater core.....
JWC 3's Avatar
JWC 3
Yes it may . If coolant is too low , not enough to properly flow through the heater core . Can be low enough to not heat , and not overheat . Get the radiator fixed or replaced . A slow leak can turn into a fast leak quickly !
Old Nov 25, 2013 | 08:48 PM
yetiman38237
also, if heater control valve is still connected to dash then the valve may be stopped up, heater core could be clogged. I would recommend unhooking heater hoses and running hose water through them to see if you can dislodge anything.......
Old Nov 25, 2013 | 08:49 PM
yetiman38237
small steps, lol....
Old Nov 25, 2013 | 08:52 PM
JWC 3's Avatar
JWC 3
This would be the next step if full of coolant
Tyler Grey's Avatar
Tyler Grey
Okay I can do that. About that clunking. It sounds like i'm going over a bump on the road but it's like every second. It's an even interval between clunks. U-joints maybe.
Old Nov 25, 2013 | 09:02 PM
Tyler Grey's Avatar
Tyler Grey
I checked the coolant and that's full soo
