My 1983 F-250 project.
Old 02-20-2015, 07:51 AM
BiGGreen350's Avatar
BiGGreen350
BiGGreen350 is offline
You Bet!!!
couldnt pass up the opportunity to pull the cummins with the 7.3 lol
  #92
Old 02-20-2015, 10:19 AM
1986F150six's Avatar
1986F150six
1986F150six is offline
Originally Posted by BiGGreen350
You Bet!!!
And, I bet you stayed ahead of that Dodge all the way home!
  #93
Old 02-20-2015, 04:42 PM
dazedandconfused's Avatar
dazedandconfused
dazedandconfused is offline
The 7.3 sure knew it was back there to especially on these back road Hills. It did fine for a lifted stock auto truck though. I know most don't care about this build since I'm putting a Cummins in it. For those that do here are some more pics of the donor. Its a 99 24V NV4500 truck with 168k miles.
  #94
Old 02-21-2015, 09:33 AM
BiGGreen350
looking good!
gonna be a great donor, and good deal on it too!
  #95
Old 03-10-2015, 07:05 PM
dazedandconfused
Got the NV4500 out today. Inside wasn't as bad as I was thinking but the dam case is cracked from the idiots cutting corners putting it together last time they "fixed" it.
Input shaft bearing was gone.
Well I pulled the rest of the trans apart. I fought 5th gear for over and your to get that dang thing off. Everything else looked great inside the transmission though. I'm pretty sure this had a 241DLD behind it. Does anyone know if the input shafts are interchangeable from the 241DLD and the 241DHD? I have that 241DHD behind the 47rh that will accept a speed sensor. I'd like to use it since my 10.25 rear doesn't have one.
  #96
Old 03-10-2015, 07:09 PM
dazedandconfused
Removed the broken bolts from the bell housing today. I also cleaned, sand blasted and painted it and the tail housing.
I made a little progress on the donor today.
  #97
Old 03-10-2015, 07:16 PM
dazedandconfused
Blasted and painted trans case. My rebuild kit minus my shim set showed up today. I also have everything loose on the engine except motor mounts so its ready to come out.
  #98
Old 03-10-2015, 08:59 PM
BiGGreen350
lots work in one day Andy!
  #99
Old 03-10-2015, 09:05 PM
dazedandconfused
What can I say. Lol
  #100
Old 03-14-2015, 07:03 PM
dazedandconfused
Another day, another mess. Pulled cab and steam cleaned everything today including the Ford frame.
Also got my tools and shims so time to build the NV4500
  #101
dazedandconfused
Next is to put the trans together and make engine mounts.
  #102
Old 03-15-2015, 12:49 PM
BiGGreen350
looking good!!!
  #103
Old 04-20-2015, 08:41 AM
84XLF150's Avatar
84XLF150
84XLF150 is offline
any updates??
really liking the re power I've never done a 24v only 12s so its a little interesting knowing the motor is longer just wanting to see how it fits
  #104
Old 04-20-2015, 03:55 PM
dazedandconfused
The last parts for my transmission came in last week. The 24V is the same length as the 12V so figment should not be an issue. I also swapped tail shafts on my transfer case to give me a speed sensor. I pulled the seats out cleaned them up as well. I'm back to working 70+ hours a week so not much time to work on it.
  #105
Old 04-20-2015, 07:49 PM
BiGGreen350
were all waiting for something decent to happen for progress on tis project andy
Quick Reply: My 1983 F-250 project.
