Back up lights
Old Nov 26, 2013 | 06:15 PM
Stewart_H's Avatar
Stewart_H
Originally Posted by Snowseeker
... but while in the X using the mirrors stuff just isn't lit well enough for my liking.
Ah, ok, yeah, I understand that.
My expectations were met when I installed mine. But I didn't have high expectations. I figured it would be a bit brighter, but usable lumens/brightness/seeing ability I figured wouldn't be very high.
I'm installing a set of fog lights on my hitch in order to light up the back. I just need to find one of these....
...so I can get it done!
Stewart
Old Nov 26, 2013 | 06:30 PM
Apocalypse's Avatar
Apocalypse
What bulbs are you guys using for the OEM lights? I'd like to swap to some LEDs.
Old Nov 26, 2013 | 06:32 PM
Stewart_H's Avatar
Stewart_H
Mine are CREE LED's from Retro-Solutions.
Stewart
robert_l_ross's Avatar
robert_l_ross
Simple halogen's from Pep Boys...rubber housing so if they hit something they can flex a bit before breaking:
Old Nov 26, 2013 | 06:36 PM
Kiss4aFrog's Avatar
Kiss4aFrog
I wired up a pair of auto store tractor/utility lights to the underside of my rear bumper and added a lighted switch to the dash. I use them when I'm backing and also loading so I didn't tie them into my reverse lights. The lighted dash switch is mandatory so you don't forget to turn them off before heading down the road. I'm in MN and have to contend with ice and snow so I ran the wires inside plastic PVC as the first year ice built up on the wiring and pulled it down.
I really like the LEDs, just waiting for them to be a bit cheaper so I can upgrade to them. Already changed over my interior courtesy lights to LEDs.
Snowseeker's Avatar
Snowseeker
I'll send you my LED's for chea.....errr, better take this to PM's.
Last edited by Stewart_H; Nov 26, 2013 at 06:41 PM. Reason: that would be appreciated! ;)
Old Nov 26, 2013 | 06:44 PM
RACERX7775's Avatar
RACERX7775
Stock reverse lights for me. And for me, there is no sense replacing them because I have the bright lights on the hitch.
Old Nov 26, 2013 | 07:06 PM
acf6's Avatar
acf6
4 - 4" cree LED squares, and cree led projectors in the tail lights
Old Nov 27, 2013 | 12:18 AM
CLINT-THE-GREAT's Avatar
CLINT-THE-GREAT
Posting Legend
Anyone have a comparison of the lumens for Halogen vs LED?
-The Great
Old Nov 27, 2013 | 01:19 AM
Stebs's Avatar
Stebs
Ooooo.... I like the idea of putting some under the truck like that!
Old Nov 27, 2013 | 01:40 AM
robert_l_ross
...SO stolen!!!!
Old Nov 27, 2013 | 07:51 AM
Gene Horr's Avatar
Gene Horr
-The Great
One problem is that the specs are a little, ah, chineesy. Not quite the no relation to reality situation like the import air compressors but still tough to compare. Another factor is that a proper LED "bulb" already directs most of its light in one direction whereas other types of bulbs are more omnidirectional and so you wind up with more loss in the reflection and lens systems.
I've been slowly converting both my house and my office building to LEDs where appropriate (generally where you need spots or narrow floods, where changing light bulbs is difficult, or where it would be difficult to change the lamp.) I usually use power draw as the comparison. Most major brands will work with in the 3:1 - 4:1 range. e.g. If I have a 50 watt incandescent bulb then I would replace it with a 12.5 watt LED.
If no one else has actually made a comparison with a light meter for the two then the wattage ratio should get you close.
Old Nov 27, 2013 | 09:22 AM
  #28
Curt's05's Avatar
Curt's05
Wiser by FTE
The new led recessed can trims are a great replacement light. The 600-700 lumen's equal or exceed the old 65 watt indoor flood light. Then the fact you can dim them down and color of the led is close to incandescent. Here are my back up lights;
Amazon.com: 27W Watt LED WORK LIGHT Lamp Flood Light 12V/24V Waterproof IP67 LD80A: Home Improvement Amazon.com: 27W Watt LED WORK LIGHT Lamp Flood Light 12V/24V Waterproof IP67 LD80A: Home Improvement
Old Nov 27, 2013 | 09:48 AM
  #29
Vince79vette's Avatar
Vince79vette
Originally Posted by LivingLarge
I use led's and the Rigid industries Lights, very bright excellent quality.
I really like these ones. If u all get a chance watch there video on how they test them lol they burn them drag them cut them shoot them and ect crazy
Old Nov 27, 2013 | 09:54 AM
  #30
Vince79vette
Found the link. Must see
