e40d cooling
Old Nov 25, 2013 | 11:04 AM
svp_evo's Avatar
svp_evo
e40d cooling
So I have yanked my motor and I am looking for ways to cleanup/hide vacuum, electrical, and trans lines to clean up the engine bay. If I run a large remote cooler should I still keep the radiator cooling for the trans fluid?
Secondly, Any ideas on what can be deleted under the hood. i.e. Non essential or redundant vacuum, any suggestions or images would be appreciated.
Old Nov 25, 2013 | 11:30 AM
dixie460's Avatar
dixie460
Nope, you don't need the cooler in the radiator if your new cooler is big enough. Some folks will say that the radiator cooler actually helps warm the transmission up in cold weather, but in my experience (not that it gets freezing cold here) it doesn't matter when you also have the factory external cooler, since that cools it back down again after leaving the radiator.
I'd go ahead and install a new remote cooler and also a trans temp gauge so you can monitor the temperature.
I personally don't like the radiator cooler either. If it blows and you get antifreeze in your transmission, it'll destroy the clutch packs.
Last edited by dixie460; Nov 25, 2013 at 11:43 AM. Reason: Edited for clarity... was on phone when I posted
Old Nov 25, 2013 | 11:52 AM
svp_evo's Avatar
svp_evo
thanks, was thinking the same thing you said. In california if we get down to 28 degrees its really out of the norm for our winter weather. Seen some really nice coolers, and the gauge was a definite addition to this build. Im building a small console to accommodate, oil temp, oil pressure, trans temp, and A/F as well as a CB radio, couple of cups and remote power for laptop,phone charging and USB connections for stereo. It will sit over the hump and blocks the ashtray.
Old Nov 25, 2013 | 11:58 AM
svp_evo's Avatar
svp_evo
[IMG][IMG][/IMG]
Old Nov 25, 2013 | 12:48 PM
Encho's Avatar
Encho
The Southernmost Mod
Keep both, you'll be better off that way (in my experience), check the E4OD link in my signature for a write-up on the subject.
lud04X
Aug 15, 2016 09:21 AM
F350dog
Feb 8, 2016 04:11 PM
brian_06328
22
Sep 18, 2015 09:25 AM
fordsgofaster
Sep 16, 2010 07:26 AM
92exploder
1978 - 1996 Big Bronco
Aug 3, 2003 02:52 PM
