Dad's Alternator Dilemma
#676
Tom - I missed your correction on the amp/distance/gauge chart. Thanks for that.
And, I agree that #4 is adequate for the charge cable, especially as it is quite short in our trucks. But, when sizing the ground we need to think about everything that will be running through it - at the same time.
For a gasoline engine I usually use #2 (occasionally #1) ground because the large load is from the starter and that's not a long duration. Diesel would be larger. I run the cable from a starter mounting bolt to the same bolt that the battery to frame ground connects.
If I have a winch I connect its ground directly to the battery and size it appropriately based on the cable length and winch motor draw at maximum load.
#677
Blue Sea systems has a circuit wizard, available here: Circuit Wizard - Blue Sea Systems and also as an app for IOS and Android.
Unfortunately, using the online wizard says #2 vs. the app, using the same parameters, which says #4.
When they open I'm going to call Blue Sea and ask them what's up with that.
Anyway, it appears the web site version is the more accurate. He's contacting the app developers to see what's going on there and will get back to me.
He said he looked at a table using the general parameters I was using in the wizard and came up with #2, but it was right on the edge with #4 so there must be something just slightly different with the android app.
He also told me Bluesea is a sister company to Ancor marine wire and he's going to see if he can find a chart of their wire sizes giving the ohms/1000m. I can plug those in to the spreadsheet I use to see how the size requirements compare.
DSMMH
12-19-2010 08:58 AM
FoMoColover
07-07-2005 11:36 AM
