Belt & Alternator
Shouldn't be that hard should it....
The 3G is the 7.3 alternator, large case and delivers about 170amps. It requires the harness to convert it to fit the 6.0 harness. The 3G/6G have the same mount. I carry one as a spare, the harness that is. In case a parts supplier doesn't carry a 6g Alternator, I can grab a 3G and make it work in an emergency.
The 6.0 is a 6G large case alternator and delivers anywhere from 110 amps-?
2003-3004 are normally 110 amps. The 2005 is a 140amp model and there are custom ones putting out upwards of 350Amps... but those are big money and sometime difficult to receive warranty service and long shipping delays.
Most say, use a local parts supplier so warranty service is easier. if you break down, readily available, and get the bigger 140amp alternator in new condition so you get a lifetime warranty. To compensate for the large amp draw during glow plug on-time, use the smaller pulley to get more RPM to increase charging output.
Also upgrade the cables to handle the higher current flow by adding a second cable to the system from the alternator mounting bolt bracket to - battery terminal, clean all battery cable grounds and add additional cable from the + alternator post to the passenger side + battery to reduce amperage loss due to impedance of the smaller cable.
Goodyear belts are fine, Gatorback are also good. I think most are fine for our trucks, just keep them in good working order.
Large case 6G 140A with small pulley works fine for most, you might get a bit more out of a 135A 3G large case, but as you point out, requires the harness...
Here's the pigtail you'll need to convert to the 3g large case. This is what I did. The pigtail is well made and clips right on. It also allows you to use either alternator if you got in a bind.
http://www.ebay.com/itm/Alternator-Conversion-Harness-Connector-Lead-Adapter-Ford-6G-TO-3G-w-Stator-lead-/200976771001?hash=item2ecb2627b9&vxp=mtr
I'm sure that unit is a good unit, I've not heard anything to the contrary.
Belt & Alternator
As far as local rebuild shops, I have found that you will need that warranty service.
Now if you want a pretty Anodized one with high output, there are plenty of companies willing to take your money!
I agree though, if you need high amps (or just want it), then go for it, but be prepared to replace the high amp units more often than you would like to! Otherwise stick to the 140 to 190 Amp units that have a good warranty.
My truck is an '05 with 83K miles on it, just got it last year. My alternator went bad at the beginning of the summer. When I was troubleshooting it, I discovered it to be a remanufactored unit. So, in 83K miles it has had at least 3 alternators in it! I called around to several of the local auto part stores and all they had were reman's in stock. I figured I'd try a different approach and go with the Bosch, no core charge, plus it was a lot cheaper than it is now on amazon and way cheaper than any at the parts stores were at the time. Can't be worse I figured... If it goes bad, I'll get one from the local parts store with a lifetime warranty to replace it with while I deal with Bosch getting a replacement. It's not a daily driver for me, so I might not even need to do this. Then just keep swapping back and forth with a spare on hand. Seems ridiculous that they only last about 30K miles on average! But, in a previous life, I had an S-10 that wanted a new fuel pump every 35-40K. I'd rather this evil!
