When to plug in?
Old Nov 24, 2013 | 02:23 PM
Brettboat's Avatar
Brettboat
When to plug in?
I'm trying to figure out at what temperature I should consider plugging my truck in. So far I've had the truck down to about 28 degrees cold start. Cycle the glow plugs 3 times and starts up instantly. What do some of you guys tend to do?
Old Nov 24, 2013 | 02:30 PM
tshrager's Avatar
tshrager
What are you doing to cycle glow plugs? They stay on about 2 mins after the WTS light goes out depending on EOT. If GP system, batts and starter are up to snuff, you shouldn't need to plug in. Especially in Atlanta. It's 26 here in Ohio today, truck has sat for a couple weeks and it fired right up without being plugged in.
Old Nov 24, 2013 | 04:45 PM
madMatador78's Avatar
madMatador78
x2 on good batts, glow plugs, and starter. It was about 15 here this morning, and I glowed mine, gave it about a 5 count after the light went out and started up no problemo.
Although it does make it start nicer plugged in. I was told 40 or below you should plug in. But its not a requirment. I would say below 0 you might want to plug in. But like alot of things it depends on your preference and more importantly how your truck deals with the cold.
Old Nov 24, 2013 | 07:09 PM
Diesel_Brad's Avatar
Diesel_Brad
Technically the truck NEVER has to be plugged in. It is easier on the truck and it makes warm ups faster. I like to plug mine in anytime it is 30 or below. I have a timer kick in on 3 hours before start up
Old Nov 24, 2013 | 07:35 PM
tshrager's Avatar
tshrager
This is another great idea that often gets overlooked. Putting a timer on is a great idea and has always worked well for me in the past.
Old Nov 24, 2013 | 08:57 PM
osu711's Avatar
osu711
I went outside and fired mine up a few hours ago 3 sec count after WTS light went out, fired up first try, w/o being ran in a day. (was down between 15-19 this morning. high of 20-somthing today)
Old Nov 25, 2013 | 11:25 AM
LeoJr's Avatar
LeoJr
Was 32 this morning (I know that's not too cold but it is for Texas!) for an hour and the WTS went dark near instantly. Cycled the key again just to be sure, same thing, WTS wait not needed. Fired right up as expected. I think the plug heater warms it faster than the engine running itself!
Old Nov 25, 2013 | 12:04 PM
mjunk1's Avatar
mjunk1
I plug mine in if it is going below 35 just because I need to replace the glow plugs and haven't done it yet. A couple hours on the plug and it doesn't smoke when I start it. If I forget it will still start but I usually cycle the plugs a second time and let it sit there for a minute or two each time. But it is LOUD - i guess piston slap and stuff.
Old Nov 25, 2013 | 12:33 PM
madpogue's Avatar
madpogue
Once again, cycling the key does NOTHING. The glow plugs run MUCH longer than the WTS light.
I totally spaced on plugging in yesterday, no plans to drive the truck, but I wanted to replace the fuel filter before the snow flew. 25F, an extra five-count after the WTS light went off, a slightly slow crank and vroom. I'd say 25-30F is a good threshold for plugging it in. And DEF use a timer; anything more than 3 hrs run time is wasted, and depending on your per-kWh rate with your utility, it costs about a dollar, more or less, for every 6 hours.
Old Nov 25, 2013 | 12:44 PM
mjunk1's Avatar
mjunk1
I just watch the guage - if it is way down then I figure the GPs are pulling. When I start the truck I notice it stays low for a while and then kicks up to where it always hangs out (don't have the numbers in my mind right now). I figured that was the best way to tell.
Old Nov 25, 2013 | 05:02 PM
LeoJr's Avatar
LeoJr
Understood, and can tell that they are still energized by the volt gauge and the speed of the blower motor. This is part of the motivation for my mod that lets me lock the truck with the remote fob while the engine running for the times I don't want to have everything run through the start up cycle again while I fuel up or similar.
It has been my observation that the WTS light stays on longer when the engine is colder, and after it has warmed up doesn't stay on at all. This is what I was trying to say earlier, is that after an hour on the block heater in 32 temps the WTS light did not stay lit, much like it was already warmed up.
Old Nov 25, 2013 | 06:46 PM
mjunk1's Avatar
mjunk1
My temp gauge actually reads much higher when it is plugged in. It is right at the bottom of the markings I think, like it had been running for 5 minutes or more. Plus the engine is much quieter and you don't hear as much piston slap (if that is what it is - I'm no expert on engine noises but it sounds like it to me).
Old Nov 25, 2013 | 07:36 PM
OldWoodsDiesel's Avatar
OldWoodsDiesel
In my opinion, you plug in when in when it's ~35f or below and one or more of the following are true:
1. You want your engine power and heat to come up much faster
2. You have a bunch if glow plugs out or other GP system problems
3. You have a weak starter or weak batteries.
Otherwise there is no 'requirement' for ever using it.
Also - the block heater only helps if it is not burned out and the cord and plug prongs are in decent shape. Otherwise it won't do much/anything notated how long it's plugged in - like mine!
Old Nov 25, 2013 | 08:17 PM
tshrager's Avatar
tshrager
Add weak batts and bad GPR/wiring to that list.
Old Nov 25, 2013 | 08:28 PM
OldWoodsDiesel
Done and done.
