Air Filter Box
Old Nov 24, 2013 | 09:38 PM
rla2005's Avatar
rla2005
Originally Posted by boonslick
Hello and good morning rla2005
Thank you for the education as I most certainly need it.
I am going to upload the pictures from Photobucket as I opened an account with the website.
Thanks again and thank you for all of the help you have given me on my threads and replies.
Boon
P. S. I saved this page so I can use it for future photographs. I forgot to inform you that my pictures are JPEG. Will it work?
Very common format that most people use, including me........
Old Nov 25, 2013 | 05:26 PM
EPNCSU2006's Avatar
EPNCSU2006
Yes, the vacuum line will originate at the vacuum tree on the intake manifold. You can cap the port there. Be sure to trace the line all the way back to the tree because there are a few other red vacuum lines at the plenum.
Old Nov 25, 2013 | 05:39 PM
boonslick's Avatar
boonslick
Vacuum Lines
Hello and good evening.
Will the removal of the vacuum line cause any issues? The engine should be able to breathe a bit better because of the larger snorkel of the 4.9L. Would you agree?
Thank you for your help!
Boon
Old Nov 25, 2013 | 05:48 PM
EPNCSU2006's Avatar
EPNCSU2006
It will certainly breathe better. I have not had any cold-weather issues by removing the heat riser. Try it and see, you can always put it back if you experience any problems. Also make sure to cap off the unused vacuum port - it will be a vacuum leak if you don't.
Old Nov 25, 2013 | 05:56 PM
boonslick's Avatar
boonslick
Hello again.
That sounds good and this is the start of removing all unnecessary plumbing; air pump and all of the plumbing and installing an idler pulley.
Boon
87thhunter
Jun 16, 2014 03:02 PM
wtroger
1983 - 2012 Ranger & B-Series
Mar 29, 2014 03:17 PM
05ExcursionLTD
1997 - 2003 F150
Sep 18, 2009 04:29 PM
murph1
1997 - 2003 F150
Nov 6, 2008 10:18 AM
johnnieb
Jan 17, 2004 01:19 AM
