Glow Plug ohm test
Old Nov 22, 2013 | 11:25 PM
1L243's Avatar
1L243
Glow Plug ohm test
My truck has been having some hard start issues with smoke on these cold mornings..(32 degrees)
I first tested my GPR. It was 12.5 on the battery side and 11.2 on the relay side.
Next I went to check the glow plugs by pulling the connector on the passenger side valve cover gasket. I grounded the multi meter on the negative battery and touched the first GP pin ...Nothing...The meter did not even move.....Tried the next pin again nothing....In fact none of the four GP pins on the passenger side registred on the ohm meter. Tried a different meter still nothing..... Tried grounding on the ac bracket...nothng.....
Did not have time to check the drives side.. What's going on?
Old Nov 22, 2013 | 11:51 PM
DND58's Avatar
DND58
You are reading resistance (ohms) correct. What happens if you read the injector pins to the center common pin. If still no readings, may be time to look for UVCH issues.?
Old Nov 23, 2013 | 12:37 AM
1L243's Avatar
1L243
I replaced UVCH last year with new OEM gaskets and harness. I think if the UVCH was that messed up the truck would not be running that good. Must be somehing with my method... I will go back at it tomorrow make sure I got a proper ground.
Old Nov 23, 2013 | 06:35 AM
HKusp's Avatar
HKusp
Originally Posted by howellt39
Jason, did you already ohm out the glow plugs on the exterior plug atop the VC harnesses? It's very quick (less than 2 minutes) and will verify that:
a. your GP's are good
b. all GP's are connected (had an UVCH done at a dealer after it failed far from home and found out they didn't connect two of them, so I'm a bit jaded...)
Just thinking that jumping the relay won't do any good if the juice isn't getting all the way to the GP's.
9 pin connector, use the center (position 5) as the ground, ohm out the 4 at the ends of the plugs, so positions 1,2,8,9. Should all be less than 2 ohms.
Quoting howellt from a cold start thread I had last year. This is the procedure to check them.
Old Nov 23, 2013 | 10:56 PM
1L243's Avatar
1L243
Turns out all four glow plugs on the passenger side were out. Never would have guessed that..Pulled them out and put new ones in.
ms1780
Dec 27, 2009 07:43 PM
lawngrease
26
Nov 2, 2008 07:56 AM
pmasley
27
Mar 14, 2008 06:29 PM
Jager
Feb 3, 2008 05:13 PM
tommyj92028
Dec 19, 2006 10:22 AM
