First Time High Coolant Temps While Towing
Old Nov 23, 2013 | 05:30 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
The fan is going to turn more at higher speeds due to the ram air effect thru the radiator.
All I know about the O'Reilly pumps is the cheaper unit has a metal impeller which is a plus.
Josh
Old Nov 24, 2013 | 12:51 AM
BLADE35's Avatar
BLADE35
Yours acts exact same as my 2003 Its normal for an 03 its just the Programming
His fan wont ramp up till 218*f ECT then FSS will hit 1500rpm+
Its the Exact reason I want to Change the Fan rpm vs Temps on mine with a Custom tunner Get that Fan to Kick in a little sooner
Only thing I can figure was they was trying to save MPG
By Trying to control the temp throughout the Range of the Thermostat But once that thermostat is Maxed out around 218*f then Give it the Fan
Old Nov 24, 2013 | 09:02 AM
69cj's Avatar
69cj
Originally Posted by Bullitt390
You're running the original t-stat because you're truck hardly has any miles on it.
And I was referring to his ECT/EOT temp spread and not the ECT temp by itself.
Josh
There seems to be many here that are having trouble getting the ect's up with new t-stats. Many of them also are not making 60,000 miles.
Old Nov 24, 2013 | 09:04 AM
69cj's Avatar
69cj
Josh
Another plus is if it does go out it's lifetime and they are local. No waiting for one to be shipped.
Old Nov 24, 2013 | 10:28 AM
Bullitt390's Avatar
Bullitt390
True. I think the t-stat in my 05 made it to about 140,000 or so before it got weak. I still ran another 30,000+ on it though.
Josh
Old Nov 24, 2013 | 07:56 PM
Misky6.0's Avatar
Misky6.0
Went to jekkll island, ga for our anniversary, used cold weather front and observed ect had no problems staying 190-195, my ect was 205, i was running a/c on way north (85* air temp).
On way home air temp 55, no a/c.. ect 190-192 the entire time, eot 197-205. I have bpd oil cooler so the delta isn't of concern, but it does tend to cool the oil real well, unless the a/c is on..
I wonder if the t-stats just can't close enough to keep our engines warm when not working hard..
Sent from my Sprint PC36100 using IB AutoGroup
Old Nov 25, 2013 | 05:21 AM
npccpartsman's Avatar
npccpartsman
At idle my engine never gets to operating temps, even in summer. Without a thermostat at 100* ambient the highest it would get was 156 in the driveway (flushing).
Do you have the cold weather package on your BPD?
Old Nov 25, 2013 | 08:05 AM
Misky6.0's Avatar
Misky6.0
No, I think it came out after I already had mine, and honestly, I wouldn't have thought to get in being in FL. We do plan to move to Colorado in a couple/few years hence having the cold weather front will be handy..
StanleyZ
6.4L Power Stroke Diesel
101
Oct 9, 2013 06:52 AM
hasteranger
Sep 23, 2013 10:10 PM
Javo
Mar 15, 2013 12:50 PM
azchris
May 19, 2011 03:03 PM
DAVE994x4
Jun 3, 2008 05:28 PM
