6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Up Pipe Replacement
Old Nov 21, 2013 | 10:34 PM
mtmatzf150xlt's Avatar
mtmatzf150xlt
Cool Up Pipe Replacement
Does anyone know if it is possible to replace the up pipes on a 6.4 without removing the cab? It looks like it might be possible but it is pretty tight..Mine are cracked
Old Nov 21, 2013 | 10:52 PM
SANDDEMON08's Avatar
SANDDEMON08
Can be done cab on trans in on a scale of 1-10 its a 10 and thats if you can get the bolts out, the issue is some of the bolts are very hard to get too and they are usually seized.
Trans removed is a little easier, cab up is the easiest. Most techs will say cab up end of story!
If you plan on keeping the truck awhile i would look into some good quality stainless up-pipes like these http://www.rivercitydiesel.com/index...mart&Itemid=54
the stock are not great IMO and have seen alot of them fail. They make them with and without EGR and they will work with the stock manifolds and turbos
Old Nov 21, 2013 | 10:58 PM
mtmatzf150xlt
Thanks, and yeah looks like seizing is gnna be the biggest problem, that and no space. But it CAN be done...Im a tech myself for MB so do you think its worth the attempt?
Old Nov 21, 2013 | 11:12 PM
SANDDEMON08
you could try it like i said its been done, but I would proably pull the trans if you have the facility in the end it will save you alot of frustration and foul language!!!! , PB on all the bolts the night before works wonders!
Old Nov 22, 2013 | 12:00 PM
Mudslinger72315's Avatar
Mudslinger72315
I posted on your other post in the super duty section. Don't want to copy and paste, so just go read it. It can be done, it's just not easy. I will tell you this, when you are attempting to remove the bolts, have a really good socket, I bought a brand new craftsman before I started, and make sure you are STRAIGHT on the bolt and that your ratchet does not **** to one side when you try to turn it. Those bolts will round off in a heartbeat! Good luck.
camcmillen
Oct 30, 2014 12:25 PM
DanielT28
Jan 18, 2013 09:56 AM
650
Jun 17, 2011 02:51 AM
79-400-POWER
Apr 25, 2007 05:16 PM
