Modular V10 (6.8l)
Torque app
Old Nov 21, 2013 | 08:15 PM
truckfella's Avatar
truckfella
Torque app
Any V10 owners here running the Android "Torque" app?
Just got mine up and running. Just plain awesome. Wanted to compare some of my parameters to others.
Old Nov 21, 2013 | 08:40 PM
tchuck's Avatar
tchuck
For those of us who are not as smart as our phones, could you tell us what it does?
Thanks.
Old Nov 21, 2013 | 11:18 PM
truckfella's Avatar
truckfella
Torque is an app that, when combined with a Bluetooth OBD2 "dongle" transmitter, allows one to view and log ANY of the parameters that the vehicle's computer sees.
For example (and this is a short list of total available parameters): speed, rpm, engine coolant temp, transmission coolant temp, engine load, throttle position, oxygen sensor voltages, fuel trims, etc. etc.
It's an AWESOME diagnostic tool. $5 for the app, and $25 for the bluetooth transmitter -- best $30 I've spent in a long time.
Old Nov 22, 2013 | 08:03 PM
tchuck's Avatar
tchuck
That does sound like a good deal.
Old Nov 22, 2013 | 09:32 PM
Neurosciguy's Avatar
Neurosciguy
toque app
Hey, I am glad to see that someone else is running the torque app as well!! I am running it on my 08 F 350 V10 and I would LOVE to compare a few numbers. My truck is actually having some real problems right now, and maybe this could help me figure out what is going on. I have a DTC P0340 code for the camshaft position sensor. here is a start on a few numbers (because there are A LOT!!)
Absolute throttle position B: 19.6% (foot off the gas) foot to the floor goes to about 79%
Air Fuel Ratio (commanded) 13.24:1
Air fuel Ratio (measured) no data (are you getting this info?
Evap System Vapor Pressure: -8.5 Pa
Fuel Pressure: (no data recieved)
Fuel Rail Pressure (no data recieved)
Fuel Rail Pressure (relative to manifold Vacuum): 279 kPa engine off key on, 350kPa engine running
Timing advance: 10 degrees (key on, engine off)
Voltage (control module): 11.57V
I will report a bunch more stats once I can get my engine running properly. Right now it will start rough, and not rev up over 2000rpm even with full throttle. let me know how your numbers compare, and I will post some more once I get this truck figured out
Old Nov 23, 2013 | 10:29 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
I do, but not so much on my V10 - more for my Taurus SHO.
Great app. But, I must say, it's a lot easier to graph and log many PIDs with my SCT X3 tuner and LiveWire than with Torque.
What I need is a good PC application that talks to the Bluetooth dongle.
It's nice that I can leave it in the OBD-II port without sucking lots of power, the SCT X3 gets HOT when left connected for a while.
And, the bluetooth dongle and Torque work with other brands of cars, not just Ford like my SCT X3.
The Torque App is a great tool, though, can't disagree with that.
Old Dec 30, 2013 | 04:03 PM
90turbo1's Avatar
90turbo1
can you post a pic of the dongle and a pic of the app in action. I would love a way to monitor trans temps while towing without adding a ugly gauge to the truck.
this is the one I found, will this work
obd II dongle | eBay
Old Dec 31, 2013 | 08:17 AM
Shepherd2's Avatar
Shepherd2
I tried a couple of those cheap adapters but they wouldn't work with the Ford protocol, it's hit and miss. I ended up getting one of these http://www.ebay.com/itm/PLX-Devices-Kiwi-Bluetooth-Wireless-Trip-Computer-OBDII-Scanner-Auto-Car-Tools-/171205607993?pt=Motors_Automotive_Tools&hash=item27dca64239
Old Dec 31, 2013 | 09:39 AM
truckfella's Avatar
truckfella
This is the one I bought from Amazon. Works like a champ.
BAFX Products Bluetooth OBD2 Scan Tool for Check Engine Light and other Diagnostics - Android Compatible:Amazon:Car Electronics
Old Dec 31, 2013 | 11:37 AM
northwindone's Avatar
northwindone
I've been using this one...
New Version V1.5 ELM327 OBDII OBD2 Bluetooth Car Diagnostic Interface Scanner : Amazon.com : Automotive New Version V1.5 ELM327 OBDII OBD2 Bluetooth Car Diagnostic Interface Scanner : Amazon.com : Automotive
It has worked great so far with the Torque app on my Acer Iconia (also worked great on my LG Thrill before I dumped my overpriced AT&T plan) I've used it on all three of my vehicles so far for diagnostic purposes. It even allowed me to track down a 2 minute transmission “repair” on my wife's Chrysler so I wouldn't have to pay the $100 warranty deductible.
It can be a bit temperamental sometimes when trying to link to my tablet, but usually works on the second or third attempt and remains linked without issues. If could just get transmission temperature PIDS on the 350 I would be even happier. (And before some asks, yes my '99 V10 is OBDII)
Old Dec 31, 2013 | 04:10 PM
projectSHO89's Avatar
projectSHO89
I can read TFT on mine. I forget what I had to add, perhaps it was the Torque Scan plug-in, but I don't recall for certain.
Old Jan 1, 2014 | 06:34 AM
knightrider955's Avatar
knightrider955
Can I get all the same info from a Scan gauge II?
Old Jan 2, 2014 | 10:52 AM
northwindone
From the research I've done I'm pretty sure you can since the ScanGauge II can have additional PIDS programmed if they aren't included. I was very close to buying one myself (and still might). The one downside is that you can only have 4 parameters at a time displayed on the SGII. Whereas with the Torque app you can have as many as your screen size will allow. Which for me is actually too many as I've been using with a 10" tablet. The thing I do like about the SG is that there is no BT tethering, you just get in the truck and go and it works without any setup effort and can be left installed permanently.
Old Jan 7, 2014 | 12:21 PM
El Camino Man's Avatar
El Camino Man
I cant seem to find the Torque app on my Iphone? Does it have a more specific name than just "Torque"?
Old Jan 7, 2014 | 12:38 PM
truckfella's Avatar
truckfella
I'm not 100% sure but I think Torque is only available on Android. Maybe someone else here can confirm (or deny).
