here are my last 2 UAO from a local cat dealer. Cooling system was pressurized to 15 psi from 15 mins and saw a pressure drop of 1/2 psi. Hooked up psi guage from degas bottle and drove with a few WOT runs and pressure never got above 10 psi. Cap pressure tested good. EGR valve is bone dry. I see no evidence of coolant anywhere on top of engine but the front cover around the lpop is a little damp with oil. For some reason i can't attach an image
Im wondering if the high potassium levels are because i use archoil.
I think that's very possible. Unless you can find a chemical analysis or MSDS somewhere I'd send a virgin sample of Archoil with your next UOA to see. It's very unusual to see coolant in oil on a 6.0, but I'm sure it's possible.
Im guessing the trace amount is maybe a drop at most, but who knows
