Aerostar Torque Converter
Old Jun 17, 2002 | 09:04 PM
Aerobud's Avatar
Aerobud
Post Aerostar Torque Converter
I have a 94 Aerostar 3.0L with 102,000 miles. Just had it tuned up and transmission fluid & filter changed. I had these done in my quest to resolve what appears to be the torque converter losing lock-up after being out on the highway for about 40 miles. It goes in and out of lock-up every minute or two. I have read elsewhere on this site that it could be the throttle position sensor, EEC module, a solenoid or even the brake switch (by the way, if I barely touch the brake pedal, the TC unlocks). Any help would be appreciated - I can't afford to pay a shop to "experiment" until they get it right.
Thanks!
Old Jun 18, 2002 | 09:01 PM
mickelsons's Avatar
mickelsons
Old Jun 19, 2002 | 06:20 AM
TallPaul's Avatar
TallPaul
I had posted about a similar problem in the Aerostar forum and Mikeman responded thusly:
"I've never had this happen, but a couple things that affect OD/lockup and cruise control come to mind. The brake on/off (BOO) switch will unlock the torque converter and will also turn off the cruise when the brake pedal is pressed. Throttle position is used in 3-4 shift and torque converter lockup scheduling. Check both of these out and see if they're bad."
To see the whole thread go to: https://www.ford-trucks.com/dcforum/aerostar/518.html
INLINE SIX POWER!
300 Cubic Inches of Low RPM Truck Torque! And twin-I-beams too!
"Drive a stick young man! There'll be time for automatics when you're old and unable."
Oct 28, 2007 02:22 PM
ken1mod
Aerostar
18
Oct 2, 2005 04:37 PM
handyman43358
Sep 20, 2005 05:23 PM
alpineswampman
Aerostar
Feb 4, 2002 07:34 PM
farmpaw
Aug 12, 2001 06:39 PM
