5.4l 3v Broken Spark Plug Removal Method
Old Nov 20, 2013 | 09:32 PM
makuloco2000's Avatar
makuloco2000
So yes I am following the method Lisle spells out but with the tips I have learned over the years from using this tool so much. With my video I got you in as close as possible to really see what the process is so you can see someone else do it first before you attempt it so you can have a successful extraction plug after plug. I really hope this helps as many really shy away from this kind of stuff.
Old May 23, 2014 | 08:18 PM
makuloco2000
Unfortunately we are starting to see more an more broken plugs that are very difficult to extract and require alternate methods including drill bits etc. One day I will do a video on the methods I have found works every time and so far have never had to pull a head due to stuck plug issues even the lisle tool can't pull.
Old Jan 31, 2015 | 04:06 PM
makuloco2000
Also here is a new video on what to do when the Lisle tool breaks while trying to extract the broken spark plug-
makuloco2000
Aug 30, 2021 02:24 PM
ugltrk
Aerostar
13
Jan 10, 2018 05:03 PM
makuloco2000
Jan 31, 2015 05:36 PM
makuloco2000
Jan 31, 2015 04:03 PM
