coolant question
Old Nov 20, 2013 | 05:23 PM
JAMSRF250's Avatar
JAMSRF250
coolant question
I will be flushing my coolant tomorrow. Everything I've read says to use 4 gallons. Is this all that is required or will it hurt anything if I use 5 gallons. I will be using Rotella Ultra ELC. I had to purchase a case (6 gallons) and thought I use 5 and save one gallon for future top offs if needed.
Old Nov 20, 2013 | 05:35 PM
cps's Avatar
cps
A 50/50/mix is best unless you live where it gets super cold. Make sure you do a good flush before hand.
Old Nov 20, 2013 | 07:29 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
If you follow the procedure as outlined by Gooch, you only need 4 gallons. Save the other 2 for what ever or sell them. You want to aim for a 50/50 mix, and by adding 4 gallons of concentrate you will get just about that mixture because some water from the flush stays in the block.
Old Nov 20, 2013 | 08:11 PM
t.scottNDU's Avatar
t.scottNDU
I personally keep a bottle of 50/50 premix for top offs, that way I don't get the ratio all out of whack. Not sure if that's correct, but makes good enough sense to me.
Old Nov 20, 2013 | 08:33 PM
JAMSRF250's Avatar
JAMSRF250
Thanks for the replys. I will go with the 50/50 mix. And yes I plan to follow the Gooch procedure.
Old Nov 21, 2013 | 06:45 AM
Liquid10Rider's Avatar
Liquid10Rider
I did the coolant flush about a year ago and followed it to the t and couldn't be happier with the end result and i also mixed a few bottles and kept one on the truck and one at home.
Pipedr
Jun 1, 2016 11:31 AM
jaxmark
Escape & Escape Hybrid
Feb 2, 2011 09:51 PM
Pony Power
Sep 3, 2006 07:38 AM
Flaw
1997 - 2003 F150
13
Nov 5, 2005 03:06 PM
Annihilator
Dec 3, 2004 08:21 PM
