Tune up causes stumbles upon acceleration!?!?!
Old Nov 18, 2013 | 05:18 PM
dougjohnson72's Avatar
dougjohnson72
I just acquired a 1991 Ford F150 with a 300 6 cylinder and 5speed trans. Ran pretty good but since I knew nothing about its history I did a full tune up. Cap, rotor, plugs, wires, o2 sensor, serp belt, oil, filter, air filter, pcv valve, breather filter. When I crank it up it purrs like a lil titty tat. Going down the road now under acceleration it stumbles. Back off and it is smooth. Idle is smooth. Acceleration stumbles. I bought the fuel filter but didn't get to it last night. I will be putting it on tonight but I doubt that has anything to do with it.
Any ideas?
Old Nov 18, 2013 | 10:18 PM
joey2fords's Avatar
joey2fords
since it ran fine before, it would be a good idea to go back and check your work ...
Old Nov 18, 2013 | 10:19 PM
joey2fords's Avatar
joey2fords
since it ran fine before, it would be a good idea to go back and check your work ... is the rotor seated properly ? cap screwed down properly ? plugs tightened ? plug wires all seated properly ? firing order correct ? also, make sure you didn't knock off a vacuum line or break one of the plastic nipples that they connect to (speaking from experience here) .
also, with such crappy parts being made these days, if checking all these things doesn't make any difference, you could try swapping in the old rotor, and then cap, one at a time, and see if anything changes.
Old Nov 19, 2013 | 08:51 AM
1986F150six's Avatar
1986F150six
Good suggestions, joey2fords!
Old Nov 19, 2013 | 09:13 AM
dougjohnson72
Thanks. One question. I told my "helper" to put dielectric grease on the distributor cap contacts. He put it on the contacts INSIDE the cap. Anybody know if this is bad!?
Old Nov 19, 2013 | 09:36 AM
Harte3's Avatar
Harte3
I don't know that it is bad. I usually put a very small amount on the top and bottom sides of the rotor and also use it (petroleum jelly) on all electrical connections.
Old Nov 19, 2013 | 02:29 PM
Harte3's Avatar
Harte3
"since it ran fine before, it would be a good idea to go back and check your work"
X2 on what joey2fords said.
Old Nov 19, 2013 | 04:58 PM
bill06447's Avatar
bill06447
The grease goes outside, under the wire boots. If you got it on the contacts inside the perimeter of the cap, that would be your problem. ~Bill
Old Nov 22, 2013 | 06:46 PM
dougjohnson72
thanks for all the replies I found the problem... I wish I could upload a picture easily from my phone. the rotor is destroyed not sure how or why.
I love this truck / this engine cause this s.o.b is a champ to even run with this rotor button looking like this!
Old Nov 22, 2013 | 09:02 PM
bill06447's Avatar
bill06447
Clip on cap uses a different rotor than screw on cap-the two are similar but not interchangeable. Check you got the right cap/rotor combination. ~Bill
Old Nov 30, 2013 | 12:30 PM
dougjohnson72
I was using correct part. Whatever the reason, it runs great now. Even with a little dielectric grease on the internal cap contacts ;-)
GMan1
Apr 6, 2009 11:02 PM
wcsd106
Aug 23, 2006 11:58 PM
F-150Guy
Feb 3, 2005 03:13 AM
Pagemaker
Aerostar
Jul 25, 2004 10:17 PM
MarkP
Aerostar
Feb 8, 2002 11:00 AM
