Sponsored by: Real Truck
EGR Issues ????
Old Nov 17, 2013 | 04:07 PM
PortlandSmoke's Avatar
PortlandSmoke
EGR Issues ????
Hello. I have a 1999 Ford F350 5.4L 4x4. I had a check engine code on my truck a couple of months ago. The truck was running fine then. The light went away and I forgot about the issue. In the last week the truck began to run like crap; hesitation during hwy speeds. The truck is running with hesitation in 3rd, 4th, and 5th gear. In low gears the truck seems to run just fine. I have changed the EGR valve as well as the fuel filter. Check engine light is not on but the problem has not gotten any better. Any suggestions. Wasting money on parts that aren't fixing the issue.
Thanks.
Old Nov 17, 2013 | 06:26 PM
senix's Avatar
senix
suggest you go to a auto parts store and get the codes read. It is probably still in there. You can do that for free at most auto parts stores. They may give some clues to trouble shoot with.
How many miles on this motor?
Old Nov 17, 2013 | 10:37 PM
PortlandSmoke
The code is associated with the egr. 135k.
Old Nov 17, 2013 | 11:55 PM
AllAboutDaZ's Avatar
AllAboutDaZ
have you checked the TB for carbon build up? sometimes some of the ports in TBs get clogged and cause issues.
Highriser4
Jul 17, 2012 10:05 PM
uniquemicro
Apr 20, 2009 02:09 PM
Iron Horseman
Mar 22, 2006 01:02 AM
christaylor
Feb 29, 2004 08:00 AM
J_U_S_T_I_N
Dec 11, 2001 09:06 PM
