Sponsored by: Real Truck
need hub help
Old Nov 17, 2013 | 03:40 PM
punishercustomz's Avatar
punishercustomz
need hub help
I replaced my front axle u-joint now I'm having trouble getting the manual hub back on. Of course I tried to get it with a rubber mallet and I broke it. Its just the switch that turns that broke can I get that part or will i have to replace the hub? Also what am I missing why am I having such a hard time getting it on? Watched several videos and it should just slip right in
Old Nov 17, 2013 | 03:57 PM
Bigpipes 35's Avatar
Bigpipes 35
I don't think you can get just the switch but contact the hub manufacture and check. The only thing I can think of is that the axle shaft is not fully seated in the front differential for some reason, check the other side and see if it sticks out further on the problem side.
Old Nov 18, 2013 | 07:56 PM
punishercustomz
OK looks like its not in all the way. Is there a trick to getting it in?
Old Nov 18, 2013 | 08:04 PM
Bigpipes 35
Did you replace the big vacuum seal when you did the U-joints, If so did you get the seal driven all the way on ?
Old Nov 18, 2013 | 08:09 PM
punishercustomz
You mean the big one that goes inside the wheel barring assembly? I bought a new one but could not get it on it was too tight so I used the crappy old one. Do u think that's the problem? Is there a trick to getting that on? I was afraid of ruining it by forcing it
Old Nov 18, 2013 | 08:17 PM
Bigpipes 35
It is extremely tight and requires a specific tool to drive it on. That could certainly be the problem as there is nothing else to keep the axle shaft from going in all the way. Did you read the Link I gave you the other day about ball joint replacement ?
Old Nov 18, 2013 | 08:28 PM
punishercustomz
My phone wouldn't pull the page up. Do they rent this tool at parts store?
Old Nov 18, 2013 | 08:31 PM
Bigpipes 35
I doubt it but you could try, In that thread I linked you to it shows how to build the tool cheap which is what I did. If you were closer you could use mine. You really should read through that thread I think it would be quite helpful..
Old Nov 18, 2013 | 08:43 PM
punishercustomz
Yeah I just looked. I got a buddy at ford I'm gonna see if he will just press it on for me
Old Nov 18, 2013 | 08:47 PM
Bigpipes 35
There ya go. Did you make sure all your washers and snap ring went on in the correct order?
Old Nov 18, 2013 | 09:22 PM
punishercustomz
Yes I just want this project to be over with! What a hassle! I installed a 10" lift on my 08 in less time than this is taking
Old Nov 18, 2013 | 09:26 PM
Bigpipes 35
Ya I hear ya. It sucks when a seemingly simple project drags on like this and most likely over some stupid little issue..
Old Nov 20, 2013 | 02:14 PM
punishercustomz
OK made myself one of those handy tools got her all together and figured out why I couldn't get the hub on. The splines on the axle were marred up from my hitting it so I took my cut off and very gently hit the inside of the grooves (tried file first couldn't get it enough). Slides right on now! Just waiting to get the new hub and I'll be able to try it out for sure. Thank you so much for all your help big pipes!
Old Nov 20, 2013 | 04:47 PM
Bigpipes 35
Awesome, Glad you got her fixed..
Old Nov 20, 2013 | 09:04 PM
punishercustomz
OK just one more question. Can I pull the end on/off **** off and put it on my old hub? A buddy of mine had one laying around and the one that's on my truck is much better condition but the end cap is broke
