Mud Flaps!
Old Nov 16, 2013 | 10:53 PM
Trucks Unlimited's Avatar
Trucks Unlimited
Mud Flaps!
Hello, I want to get my Dad some mud flaps for Christmas and I want some that are like this: 2005 Ford Excursion | WeatherTech No Drill MudFlaps Mud Flap for Chevy, Ford, Dodge, GMC, Cadillac | WeatherTech.com But our truck is an eddie bauer and that won't work with the fender lip molding. Ford used to make one but they are out of production and there is no used market for them. If you want to know, the oem ford mudflap part # is 16a550. I don't want any that are rubber, or flap (that's ironic). Please help?
Old Nov 17, 2013 | 01:50 AM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
i've spent over a year after breaking two of mine over the winter trying to find more ford factory splash guards for an Excursion with cladding. i finally bought a set of rear ones from a fellow member they where $90 shipped just for the rears..i'm still searching for front ones.
they are not easy to find, keep your eye open on ebay and craigslist and you may luck out!
Old Nov 17, 2013 | 02:34 AM
golfmedik's Avatar
golfmedik
Lots of people buy Huskys...that is what I ended up doing and they fit perfectly.
Old Nov 17, 2013 | 06:08 PM
Trucks Unlimited
And your truck has the eddie bauer/limited trim molding?
kornfanjoe's Avatar
kornfanjoe
If I had known that I would have sold you mine instead of trashing them. I took off all four mud flap things. Broke a rear one off and like the look without.
Old Nov 17, 2013 | 06:11 PM
golfmedik's Avatar
golfmedik
Yes ... I have a Limited....
Old Nov 17, 2013 | 06:21 PM
Trucks Unlimited
Okay, it's just that on the website it only gives the option for no trim. It will still work probably though.
Old Nov 17, 2013 | 06:51 PM
garryk6's Avatar
garryk6
I went with dura-flaps when I bought my 2005 Limited Ex. When I sold it, I kept them, and they are now on my 00 XLT. But if you run bigger tires, the occasionally rub, but other then the noise, no issues (rubber on rubber).
Garry in AK.
Old Nov 17, 2013 | 07:44 PM
golfmedik's Avatar
golfmedik
Here is a pic of mine before the V/B spring swap. If you look closely you can see the splash guards.
Old Nov 17, 2013 | 08:10 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
far as i can tell any of the aftermarket companys no longer carry the flaps made for excursions with cladding. i have searched high and low and called many manufactures all with dead ends.
only option i've found is waiting for NOS ford splash guards or used...its a tough market lol
Old Nov 17, 2013 | 08:35 PM
Wacenturion's Avatar
Wacenturion
Tried to order some, but they show only front flaps for Husky. Were your flaps identical? In other words, wondering if they are the same front and rear?
Thanks
Old Nov 17, 2013 | 08:54 PM
golfmedik's Avatar
golfmedik
Thanks
I honestly do not remember. It has been quite a while since I put them on. I will try to look tomorrow and see if they are different.
Old Nov 17, 2013 | 08:56 PM
Wacenturion
Thanks...appreciate it.
Old Nov 17, 2013 | 09:06 PM
Trucks Unlimited
Now I'm 13, and I imagine, so here is an idea. You could cut the trim on the truck to where a non trim mud flap will fit. You would have to take off the trim, but I think it wouldn't be bad only because their is no market for them. What do you guys think?
Last edited by Trucks Unlimited; Nov 17, 2013 at 10:43 PM. Reason: Misuse of word.
Old Nov 17, 2013 | 11:40 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
here is a question: How flexible are those flaps? Would they crack/crush while offroad? I don't 4x4 much, but when I do I typically kiss stuff like that with rocks.
