S&B vs. AIS - With Photos
#91
The kind of weather conditions I'm talking about I've never seen in Seattle. (I'm going there tomorrow). I'm talking the kind of cold where once you get the inside of the car warmed up enough to roll the windows down, there is still a secondary window of ice remaining that you have to punch through in order to check for smoke in your mirrors!
Maine-ly in the Northeast.
#92
The kind of weather conditions I'm talking about I've never seen in Seattle. (I'm going there tomorrow). I'm talking the kind of cold where once you get the inside of the car warmed up enough to roll the windows down, there is still a secondary window of ice remaining that you have to punch through in order to see the smoke in your mirrors!
#93
#94
#95
I read somewhere that a WIX 6637 is a cheap replacement for the original Tymar... but the specs are not the same. It may be worth a couple of searches to verify.
#96
My experience:
My truck was smoky/hazy with both the K&N cone style filter and the WIX6637. I ran them for over 300K and never had a dirty intake tube or any signs of a dusted turbo. The haze was visible at night in the headlights of followingvehicles during acceleration at all throttle positions getting progressivelyworse the more aggressive I got with the throttle.
I recently swapped in the AIS (thanks Tug for the good deal!) and changed nothing else. The Haze is now GONE. Jenni can still get smoky if I get to aggressive with the throttle but in "normal" keeping up with the flow of traffic driving my exhaust is completely clean.
as a side note: the sounds I thought were cool when I was 30 are not as cool now that I am 39, the silence that the AIS brought to the cab is a big relief.I have had to re-learn to drive my truck to some extent. My first drive withthe AIS I pulled on to the county road leaving my house and did not realize I was doing close to 70MPH as I approached the first 45 MPH turn. The overall noise level in the cab is so mellow with the sensory input of the open element gone that empty the engine never sounds like it is "working" at all.
My injectors are stock originals with about 410K on them I have a 4"exhaust, wicked wheel, a builtish transmission and a PHP FU chip.
#97
#98
#100
I'll throw this out there FWIW. I just installed the S&B kit with the ram air tube on a newer Dodge. It dropped the EGT's about 200 degrees on the hot tune WOT. Noise was considerably more than stock. I know this maybe be different than what you will see on a Ford, but may be helpful. The kit installed easily, and looks good and seems to be of good quality. The dealer where I bought it told me that S&B open element flows well and filters better than the K&N elements. Can't verify that, though.
#101
#102
After reading this entire thread, it easily convinced me to make the switch from the 6637 to the S&B. Bought one from riffraff yesterday. Looking forward to the results. I was thinking of doing a couple of comparison videos showing the differences in sound from under the hood and smoke in the mirror.
#103
#104
After reading Riches post when he swapped last year or so i too took the plunge. I was running a AEM Brute force which they use a K&N dry flow filter. Its just a aluminum tube with the filter on the end. Looks flashy but fairly loud. I was debating the AIS or the S&B. After lots of reading i went S&B. Install was good its a nice clean well built system. There was far less noise compared to the AEM. But that changed after i swapped out my ww for my 2nd gen ww when i rebuilt my turbo. That sucker makes some noise now !
#105
