S&B vs. AIS - With Photos
#61
#62
I need to do that. My snorkel does not get a straight shot of air. Woodinthings was telling me he drilled 1" holes in the zoodad area of the grill, and suggested a coarse screen material might be good over that. I need to review pics of the zoodad mod and see how direct the airflow is. Want to avoid water intake through a large puddle and the like.
It is a fairly direct flow of air from where the Zoodad goes. I would be more concerned about following a vehicle during heavy rain and having the tail-stream go in then I would the rain itself.
#63
In essence, I'm not counting that reading as a win.
#65
So you replaced an injector and the air intake and then there is the changing temperatures and fuel blending. With all of that you are still claiming that it is all in the air filter? Riiiight....
#66
I've had this most recent batch of Stage IIs (and a whole new tuning provider) since February and they were all good at first - but I still had soot with the AIS and the bigger turbo. It's really cold in February around here. The #7 stick started giving me issues in the spring and I moved it to the #2 position to confirm it was the stick and not something else.
I won't try to recount the whole mess I've experienced since I got the truck, but the effects of the filter change are not subtle. My engine had this exact same configuration in February of last year, with the only real difference being the air intake. Cups and oil cooler don't count, neither does the water pump, the alternator, the ladder bars, etc....
The soot is gone with the S&B... and I'm at 4000 ft elevation right now. I'll be at 6000 feet later today and report back on that result.
#69
#70
Hard data at last: With my new faster data sampling, I can see the EBP gauge value and the turbo boost is still analog for now... the boost-fooler messes with the OBDII reading.
I shot a video (can't upload from here) and took some freeze-frames of the run. The video is only 8 seconds long, but it shows plenty.
The freeze-frames are most appropriate in this thread, where I mentioned I had issues with the intake maxing out. These shots show the efficiency of the air in vs. the air out: Bear in mind the camera had a low angle, so the analog needle will look low by about 1 or 2 PSI. The boost alarm is programmed for 34 PSI, so I'll run with that.
#71
#72
In another thread ( Air filter question ) I posted some detailed pictures and comments about the AIS when compared to a stock factory air box and stock filter or flat panel replacement filter. A few folks mentioned they ordered the AIS right away after those posts.
Now I feel that it is incumbent to interject that for highly modified performance tuned engines used for play instead of for work, there are some less restrictive, but still fully enclosed airboxes that might be more suitable choices.
Of the aftermarket units that I tested on the flow bench, the Volant flowed far and away the highest numbers under the same test conditions as discussed in that other thread, sucking in about 1,500 CFM (compared to the rough average of 800 CFM of other airbox combinations, compared to the max of 600 CFM that a stock motor can even use).
The Volant's 1,500 CFM just flat blew away every other box and combo that I tested as far as pure flow with a fully enclosed airbox (not counting open elements or partially open systems that attempted to "seal" against the truck's hood). The Volant left the AFE, the WesternDiesel, the AirMax, etc gasping for air. I remember jumping up and down as the results were showing up on the monitors of the flow bench, saying see, I told ya, I told ya. The Volant was a very under appreciated solution at that time, because unlike the competing air intake systems that had a lemming like following online, the Volant had zero internet forum marketing traction, where the purchase decisions were beginning to be made in this new era. (Witness the bump in sales of the Torque Pro app, as well as the AIS these past few days).
And thus the Volant represented the gauntlet that was thrown... the standard to beat, as far as an aftermarket performance air box and filter design where high flow takes precedence over service interval or dirt retention. The Volant was the most expensive also, around $570.00 a dozen years ago.
To beat the Volant not only in flow, but also in fit, finish, serviceability, ease of assembly, and total exclusion of hot under hood air that reduces air density... became the focused mission of the engineering company (an FTE sponsor) that provided the use of the $30,000 flow bench for me to make these factory and aftermarket air filter system comparison tests on. It took them a few years to get around to getting it done (they were pre-occupied building a world record setting diesel race truck when I was there), but this is what they eventually came up with:
High flow aftermarket airbox replacement comparison ad.
#73
