S&B vs. AIS - With Photos
That's what mine reminds me of. Not knowing anything else, I have to say I like it. Its the injectors I'd like to quiet a bit more, but the turbo sound is just right. I hope you can dial in the amount of sound you want.
Yes, and good firewall insulation... as well as carpeting. The cab noise has always been very reasonable, so Stinky's tooth gap is getting my attention.
It's too early. Filter performance issues wouldn't be seen until the higher RPMs with higher boost numbers... like passing a car on the highway.
Welcome to the forum! Was there a reason they used your truck as a test bed?
I'm constantly working on injector noise - it's the loudest thing under the hood (to my ears). This passenger jet sound may be a thing, though.
Mark
I need more wheel time, but here's the preliminary report:
Cold. I have this series of hills where my EGTs have always hit 800 degrees F winter or summer with these sticks on cruise control at 65 MPH. The new number is 700 degrees F. My cruise on the flat is marginally cooler, but that can be air temperature making that small difference at this low flow.
Clean. I used to have a puff when I passed vehicles, but the mirror is completely clear so far. I have not done any WOT runs, and I will not run the race tune anytime soon. I can say passing is more responsive without the need to bury my foot.
Loud. Cruise is fine... just a faint whistle (no louder than the rest of the engine), but 2 PSI boost (about 50 MPH) is absurd. It wouldn't drown out conversation, but a turbo harmonic is there that is clearly louder than the rest of the truck. I need to see if anything can be done to minimize it. No whooshing sounds, so it doesn't sound like the truck is trying to pull itself inside-out
I will soon put Stinky through high-altitude and AE tests... but that's not this week.
*EDIT* Noise being worked out later in thread.
Great to here your report Tugly. The real test is going to be the wife sitting next to you on a long trip. She'll either like it or say, please put it back the way it was. You mit be able to wrap the box and lid to quite it down. Waiting to see what you do.
The guy with the 200/80 PIS injectors, who's tunes are you running? It may be as easy as changing tuners. The air is out of the system right?
#28
#30
The 6637s I've heard were on stock turbos, so the sound is completely different. I'd say the S&B and 38R is slightly quieter than a 6637 with stock turbo - and zero suction noise with my setup. The 38R is notoriously louder than stock, when using the same intake... but my AIS absolutely killed the sounds of both, so I have no reference here. I'll get a vid soon, and let you guys sort it out.
