Aerostar Ford Aerostar
electrical problem
Old Jun 22, 2003 | 08:53 PM
aerostarman2002's Avatar
aerostarman2002
electrical problem
Earlier today while merging onto the freeway My battery guage shot up so far that the reading was off the guage. The warning light was also on. I was going about 85mph and the stupid thing wouldn't go into Overdrive which was making it rev a little high.. once I got into traffic and was able to slow down it went back to normal.
later off the freeway and on a back road climbing a steep hill I had to floor it to get up the hill and the guage shot up again and this time the A/C blower sped up significantly and the warning light was on again.
Any idea as to what's going on???? luckily it got mne home, and I was able to avoind reving the engine so much...
-Mike-
Old Dec 21, 2003 | 01:57 AM
RCaero93's Avatar
RCaero93
I have a 93 Aerostar Sport shortie with a 3.0 engine. I had a problem not to long ago that happend under similar conditions.
Under hard acceleration the headlights and dashlights would dim.
I took it to a local alternator repair shop. It turned out that the commutator inside the alternator was worn and out of round. This would cause the brushes to bounce and allow less voltage to the system.
Old Dec 21, 2003 | 07:14 AM
aerostarman2002
Yeah we got it fixed, a good while back... found out that with over 200,000 miles on the alternator it was so worn that at high RPM's something would short and was causing more power to go into the system...
Put a new alternator on it and it runs fine again...
I can put the padal down all I want and it will be just fine...
Now it's at almost 226k miles on it with the original motor still running flawlessly, except with the normal ford valve noise on older engines... The original transmission has the same milage on it, and has not been rebuilt.. it is showing its age, but is still very drivable. when you stomp the gas it likes to slip down to many gears, and sometimes it goes hard between 3rd and OD, I just can't see getting it rebuilt yet though..
-Mike-
