Today, I needed to back my truck out of the garage to get to some stuff on the shelf in front of the truck. I don't like to start her up and shut down in just a couple minutes. So, I backed her out and left her running in the driveway. After a while, I notice the smell of diesel fuel and I thought it was exhaust. The smell got stronger so I looked toward the truck and noticed a large puddle under the truck. It was diesel fuel. I shut her down and investigated. I saw that when I turned on the ignition, there was a spray of fuel straight up from the engine. I got my wife to turn on the ignition while I watched and found that the fuel spray was coming from the engine mounted fuel filter. Right where the fuel exits the filter and travels through a tube on top of the filter, the case split. I wonder how many dollars worth of fuel poured out of my truck. Anyway, it is about time for a filter change since I have 16,000 miles, but I didn't need my engine and driveway coated with diesel fuel! BTW, $79.99 for a filter kit fit seems a bit steep, huh?
So, anyone else have a filter fail like this?
Never heard of the engine mounted one fail, heard of the frame mounted one damaged (quite common, actually) because of its location. These are parts that I stock in the vehicle because they have the potential to leave you stranded if they fail!
I don't know if this would have left me stranded or not, but I would have left a bunch of fuel on the road if I was driving. I'm glad I say this in the driveway before driving somewhere.
Ya I'm pretty sure fuel spraying all over your engine bay might not be such a safe thing to continue driving with... even though Diesel fuel's flash point is higher and all that.
Yup. Probably would have done a lot of smoking. Now, I'm wondering how to get it all cleaned off the engine. I took several pitchers of water and Dawn dish washing detergent and poured it over the engine. Today, I'll see how well that worked when I change out the filters. If the filter kit can be had for $50 on the internet, I better get one and have it on hand, huh?
When installing your new fuel filter on top of the engine be sure to not over tighten the small bolt on the base clamp that holds the filter. If the clamp is tightened too tight, it might distort the fuel filter and eventually causing it to crack. I normally tighten this clamp just tight enough to prevent the filter from rotating. This fuel filter clamp only applies to '11-'12 trucks as I believe the '13 and up don't have this clamp.
In addition to cleaning diesel fuel, Simple Green and a water rinse works great. I've been using it for cleaning engines for many years will no ill effects.
Thanks for the advise, Troy. Since this was the original filter, I wonder if the boys at Ford over torqued it. Hmmm...Simple Green can be sprayed on the engine. I was mixing Dawn and water and pouring it on. Whenever the rain stops here, I'll find out how well my cleaning did.
Thanks for the heads-up. Glad you caught the problem before it got worse.
I guess the thing I don't get tho is; what is wrong with using a power washer type under the hood? I know you're not supposed to drown the electronics and such, but I've been washing under the hood every time I go to Buggy Bath. I have done this with every vehicle I owned for years. The only issue I have is with my 1990 Festiva work car. If you spray too much I have to take off the dist. cap and wipe it out. I don't know, maybe I'm missing something here, but I wash my engine compartment at least a couple times a year.
